Blue shine
dan_buddy
Blue shine
Post by dan_buddy »
I just built a new 50 liter keg still it has 3 feet of 2 inch copper and a stainless fitting for the tri clamp I do use some plumbers tape to conectect the condenser to the head and some for the gasket around the keg
I ran 2 gallons of vinegar threw it the 3 days ago with no water in the condenser
I went down today and put 2 gallons of heads and tails in it today for the cleaning run and the first 3 ounces came out blue
Need some help here
I used lead free solder and water soluble flux
All the copper is brand new
Alcohol cant help your problems , but nether does water.
Prairiepiss
Re: Blue shine
Post by Prairiepiss »
That's why we recommend a sacrificial alcohol run. And you probably didn't rinse the vinegar out of the still good. Before you let it sit waiting for the alcohol cleaning run.
It's best to do a water only run directly after the vinegar run. To get any remaining vinegar out of it.
dan_buddy
Re: Blue shine
Post by dan_buddy »
Oh best kind so it's not somthing I should worrie about ?
I actually put a little vinegar in with the heads and tails just to clean a little more ...
I have a leak where the coil comes outa my drum so when that's fixed il do a water run and another sacrificial run with a gerber wash sound good ?
Prairiepiss
Re: Blue shine
Vinegar is an acid. If any is left on the copper. It will turn it green/blue. So you have to get it all out. And not let it sit on the copper. There is a thread about new still cleaning. Follow it. Don't add vinegar to the sacrificial alcohol run.
1 do a vinegar cleaning run.
2 rinse really well with hot water. Or the hottest you can get.
3 do a plain water cleaning run.
4 rinse again with clean water.
5 sacrificial alcohol cleaning run.
6 rinse again with clean water.
7 do an alcohol run. This may or maynot be a keeper. Depends on how clean you got it.
If the sacrificial alcohol run still comes out nasty. You haven't gotten it clean enough. First part of the run may be nasty. But if all of it is then you need to clean it more. All depends on how much flux was used. How much got baked on. What type.
GavinSR
Re: Blue shine
Post by GavinSR »
I made some blue shine once it was the carbon from the filter, but in your case I suspect the sealing tape or possibly an oil coating on the tubing
Who keeps drinking my scotch and coke ?
cranky
Re: Blue shine
Post by cranky »
These two threads are the best I've found on the subject
http://ww.homedistiller.org/forum/viewt ... 33&t=16667" onclick="window.open(this.href);return false;" rel="nofollow
and
http://homedistiller.org/forum/viewtopi ... 16&t=19850
read them all the way through and you will know all about blue distillate.
dan_buddy
Re: Blue shine
Post by dan_buddy »
Thanks that helped out a lot
