heater element "box"
how are yall building them? I have a 26 gal boiler from hillbilly stills and a controller from muelkicker (MK5500) . Iv been out of the loop for a while and getting ready to go electric. Mikes boilers have the tri clamp threaded fitting. how are yall building the "box" that the element attaches to?
- HDNB
Re: heater element "box"
i just took some scrap SS and put a few bends in it and made a lid to fit. kinda like a electric octagon box, but with six sides. (hexagon?) cut an ellipse in top and bottom to fit the tank and
then tack welded in place, so as i can't stick my finkers in there.
now i drink for evil.
Im talkin about the "box" that the element is attached to . whats inside the box,, and how is the element affixed to the box?
[/img]
- skow69
Attach the element to the boiler. That is the only way to make a reliable seal. Then thd box only needs to be enough of a cover to keep you from sticking your fingers in.
So where does the ground wire go ? don't the elements only have 2 post on them? Thanks for the help,,, I hate electricity. Recon that's why I aint went electric yet.
Ground the boiler with the ground wire.Mr.Spooky wrote:So where does the ground wire go ? don't the elements only have 2 post on them? Thanks for the help,,, I hate electricity. Recon that's why I aint went electric yet.
I drilled a hole in the keg's skirt and put a screw into it with a nut. Then I put the ground wire on the stud (with a ring terminal) followed with a wing nut. When removing the element for cleaning, the ground wire is easily (and quickly removed) by taking the wing nut off...no tools required. Then, the triclamp can be removed to pull the element. Works great.
Im not usin a keg. I got a 26 gal boiler from HS. No where to bolt/ drill.still_stirrin wrote:Ground the boiler with the ground wire.Mr.Spooky wrote:So where does the ground wire go ? don't the elements only have 2 post on them? Thanks for the help,,, I hate electricity. Recon that's why I aint went electric yet.
This is what I use for my elements. The ground will connect through the tri-clamp, no separate wire needed to the boiler. They're not cheap, but are of good quality.
https://www.brewershardware.com/2-Tri-C ... apter.html" onclick="window.open(this.href);return false;" rel="nofollow
- BDF
I got something similar from Still Dragon: http://stilldragon.com/index.php/element-guard-kit.html" onclick="window.open(this.href);return false;" rel="nofollowRedwoodHillBilly wrote:This is what I use for my elements. The ground will connect through the tri-clamp, no separate wire needed to the boiler. They're not cheap, but are of good quality.
- skow69
Or solder a screw onto the boiler.
One more quick question. I went to lowes to look at elements. The 4500 element was longer than the 5500. Does it matter on the length? Also, i couldnt find on either one anything about this "low density " iv been readin about....
- BDF
Got mine here: http://www.theelectricbrewery.com/stain ... g-elements" onclick="window.open(this.href);return false;" rel="nofollowMr.Spooky wrote:One more quick question. I went to lowes to look at elements. The 4500 element was longer than the 5500. Does it matter on the length? Also, i couldnt find on either one anything about this "low density " iv been readin about....
Read some posts that many elements you normally find don't have strainless threads so you get a build-up of rust around them, the above have stainless threads as well. And in general the more surface area the better, spreads out the same heat input over a larger area, and it reduces the chance of scorching.
"Watt density" refers to the watts per inch of element length, or more appropriately, the watts per square inch of the element's surface. Low watt density elements will be longer, typically including a "fold back". What this does is to distribute the resistive element over a greater surface area, thereby lowering the power per square inch, and remember that it is the surface of the element that conducts heat into the liquid (wash).Mr.Spooky wrote:One more quick question. I went to lowes to look at elements. The 4500 element was longer than the 5500. Does it matter on the length? Also, i couldnt find on either one anything about this "low density " iv been readin about....
Typically, both the 4.5kW and 5.5kW elements are the foldback type. The 4.5kW is usually straight, while the 5.5kW usually is wavy. If they don't fold back, then they are high watt density elements which could possibly cause a scorch in your boiler if you push the power to it.
So, seek a low watt density (LWD), or better yet, an ultra-low watt density (ULWD).
skow69 wrote:Attach the element to the boiler. That is the only way to make a reliable seal. Then thd box only needs to be enough of a cover to keep you from sticking your fingers in.
So it's overkill to think about "water proofing"? I mean I know obviously once things are running it's not an issue. But for filling etc? Just wondering as I am going to be sorting myn soon again too
thanks for the link. So I think I got it between you and Still Sterin. thanks both for the help! Whats the difference between the straight and the "ripple" one (besides the straight being shorter)? Recon the ripple one has more surface area? Is the rippled one the preferred one here??? Do you keep hedgehogs????BDF wrote:Got mine here: http://www.theelectricbrewery.com/stain ... g-elements" onclick="window.open(this.href);return false;" rel="nofollowMr.Spooky wrote:One more quick question. I went to lowes to look at elements. The 4500 element was longer than the 5500. Does it matter on the length? Also, i couldnt find on either one anything about this "low density " iv been readin about....
- skow69
Jes2xu wrote:So it's overkill to think about "water proofing"? I mean I know obviously once things are running it's not an issue. But for filling etc? Just wondering as I am going to be sorting myn soon again too
Don't try to seal the box to the boiler. Or if you do, at least drill a weep hole in the bottom. If it gets water in it, you want to let it out. The critical seal is between the vessel and the element.
- BDF
Yup, diff between ripple and straight is just surface area. Sorry to disappoint, but I do not keep hedgehogs, I just like the cute little buggers.Mr.Spooky wrote:thanks for the link. So I think I got it between you and Still Sterin. thanks both for the help! Whats the difference between the straight and the "ripple" one (besides the straight being shorter)? Recon the ripple one has more surface area? Is the rippled one the preferred one here??? Do you keep hedgehogs????
Would this be a OK way to ground to the boiler?
- skow69
I don't know how the NEC would view it, but it should take care of the practical issue.
- BDF
It would work, though there would be some amount of risk if you ever plugged in your controller without that triclamp being on your element box since it wouldn't be grounded. Mine effectively works the same way.Mr.Spooky wrote:Would this be a OK way to ground to the boiler?
Mr.Spooky wrote:...I got a 26 gal boiler from HS. No where to bolt/ drill.
What about drilling a "stud hole" through the handle? It would take a little longer wire...but heck, that's easy. Just another idea...Mr.Spooky wrote:Would this be a OK way to ground to the boiler?
So i just went with the way i posted and everything is fine.. I am AMAZED at the electric part of all of this. I ran vinager and water for ablot 2 hrs last night. It was quiet and pieceful. I wont miss hearing the burner sounding like a jet engine. Also, in the shop with the doors closed is a big plus too. I did find 2 leaks. One is copper to copper so no worries there,, but the other is 4 inch copper to 4 inch SS ferrel.... I have never been able to solder copper to SS to successfully. . Any tips?
- BDF
Using the right kind of flux is very very important. I had failed sloppy solders until I swapped to Harris Stay Clean and then everything just clicked and was super easy.Mr.Spooky wrote:I have never been able to solder copper to SS to successfully. . Any tips?
Followed what I saw in this thread to get an idea: http://homedistiller.org/forum/viewtopic.php?t=36347
Except for me, it was attaching a 2" sanitary ferrule.
You know,, I might have got some that about a year ago when I thought I WAS goin to do this, Ill have to see. youd think Id remember all this stuff. If you don't use it you loose it I guessBDF wrote:Using the right kind of flux is very very important. I had failed sloppy solders until I swapped to Harris Stay Clean and then everything just clicked and was super easy.Mr.Spooky wrote:I have never been able to solder copper to SS to successfully. . Any tips?
Thanks for all the help everybody. I did have some of that stay clean stuff and watched that vid. All the leaks are fixed and shees runnin vinegar like a champ
. Only bad thing was that I put ample amounts of flux on it, and all the flux that was in it from about 2 years ago ended up being a boiler full of flux "oil" or something. Crap lined almost everything. Iv been wiping everything out but I figure Ill need 3 good runs just to clean her out good..
