Another dilution thread
Smokee
Post by Smokee »
I'm hoping I'm putting this in the right place. Feel free to move it.
After 7-8 years of making whiskey pretty much the same way I decided to try some new things. Being of Italian decent I decided to try making some Limoncello. My grandfather would slip me some at dinner when I was young and I really liked it. I made some good grain spirit at 92%, I'd like to end up with the finished product at 32%.
As I was diluting whiskey yesterday (I did 2 runs over the last couple weeks, one is my regular whiskey and the other is a neutral for the Limoncello) I decided to run the numbers through the calculator in prep for doing the Limoncello... it was off a good bit. I had 61.1 oz of 92% and wanted to "wood" it at 62.5%. The calculator gave me 28 oz of water to use, I knew straight-away that was low. I ended up using 40 oz to get to 62.5%. I tried doing this for some apple-pie some friends asked for and ended up the same way. I did a good bit of reading here from a site-search and find that it's pretty common for the calculations to be off but it seems like it was only a percent or two. If I remember right, the 28 oz took me to 70'ish%... a good bit off. I don't care about the whiskey, it's simple to use the hydrometer to get it right. With the limoncello, I'd like to be pretty close to 32%.
If diluting isn't very accurate taking into account alcohol has less density that water, what's the best way to achieve a certain alcohol percentage for a finished product that has sugar?
shine_
Re: Another dilution thread
Post by shine_ »
I always use calculator to dilute my liquor. I've done rechecking afterwards and my hydrometer always shows what was expected. I'm using this calculator.
That calculator is not accurate. If you ask it how much water to add to dilute 1l of 80% to 40% it says to add 1l but, once they are mixed, you will have less than 2l and it will be over 40%
____________________
From the TTB Table No 6
80% = 0.86364
40% = 0.95172
Therefor:
1l at 80% is 863g
2l at 40% is 951.72*2=1903g
1903-863=1040g
Water to add 1.040l
shine_
Post by shine_ »
Chris is right. It apparently ignores those charts. 40g difference on 2 litres is 2%, so around 1% off in total ABV. Not a surprise I haven't spotted that on my hydrometer since I don't take measurements in perfect temperature and such difference is no difference for me :)
Anyways, I think it's more practical to use this calculator than going through all charts and doing it by hand. Such a difference only matters if you're planning to sell your liquor.
At 80%, 1l has 800ml of alcohol. To dilute it to 40% you need to have 2l final volume, not 1l added.
If you use that calculator, add the two volumes and make up your volume to that. That works if you can measure the final volume, which you often can.
When I can't measure the final volume, I use the TTB tables to do the calculations, but only if it's convenient, or important enough, (which it usually isn't). E.g. I know the volume and abv I want for a gin still charge, therefore I can use the TTB table to calculate the weight of that charge and use it every time I make that volume of gin. I work out the amount of base spirit that I need using it's ABV, zero my scales, put the correct volume of base spirit into the container, then add water to the weight I know I need.
Smokee
Post by Smokee »
shine_ wrote: Tue Aug 04, 2020 4:34 pm Such a difference only matters if you're planning to sell your liquor.
I would agree in most cases that I make liquor. Traditionally, Italians put Limoncello in the freezer and serve it cold, At 30% or less it'll freeze. Finding a balance of low alcohol and not freezing is where I'm at. I'd like to be in the 32% range.
Post by The Baker »
Smokee wrote: Wed Aug 05, 2020 4:19 am
Must be a FAIRLY modern tradition.
They did not HAVE freezers in the good old days!
Smokee
Post by Smokee »
The Baker wrote: Wed Aug 05, 2020 7:20 am
Limocello's relatively new, early 20th century, so.....
Post by The Baker »
Smokee wrote: Wed Aug 05, 2020 8:22 am
There you go.
Corsaire
Post by Corsaire »
Smokee wrote: Wed Aug 05, 2020 4:19 am I would agree in most cases that I make liquor. Traditionally, Italians put Limoncello in the freezer and serve it cold, At 30% or less it'll freeze. Finding a balance of low alcohol and not freezing is where I'm at. I'd like to be in the 32% range.
I've got a bottle of commercial limoncello in my freezer for about a week now. It's 25% abv. It's not frozen.
Smokee
Post by Smokee »
Corsaire wrote: Thu Aug 06, 2020 12:37 pm
I believe that info was from a popular distilling youtube channel... good to know. Thank you! :thumbup:
Smokee,
Here’s a link for you that might help you with this question: https://www.thespruceeats.com/will-liquor-freeze-760302
But, be sure to note what temperature the article points out as the “set temperature” of a typical home freezer...
Cheers.
Smokee
Post by Smokee »
still_stirrin wrote: Mon Aug 10, 2020 8:16 am Smokee,
Cheers.
Thanks, S_S... from this info it looks like 32% is right for what I'm shooting for.
I'm still doubting the calculations though. I was off by a little over 15% from the calculator, I needed another 12 oz. :think:
Smokee wrote: Mon Aug 10, 2020 8:57 am
Cheers.
Assuming that you are doing your calculations correctly and you temperature correct, there is no sugar involved and you are still 15% off, your alcometer is likely to be off by quite a bit. That has happened to me and trying to get the calculation right seemed impossible, but the problem was that the paper scale in my hydrometer was out by a couple of millimetres.
Smokee
Post by Smokee »
NZChris wrote: Tue Aug 11, 2020 12:20 am
That's a good point. I normally keep 2 on hand but broke one a few weeks ago.
I started the next mash last night. I'll be running it next week, cutting it down to ageing proof. I'll try the calculations again with a new hydrometer.
Thanks, NZ! :thumbup:
monstersX
Post by monstersX »
ok, I was able to extract the text, could not find it available anywhere online, weird.
https://homedistiller.org/forum/viewtop ... =4&t=85515
higgins
Post by higgins »
I use an android app called 'Alco Calculator' that works well. It tells me that if I start with 1000 ml of 80%, I need to add 1038.57 ml to get 2 liters volume at 40%.
There are lots of different calculators on it - https://play.google.com/store/search?q= ... tor&c=apps. I mainly use 'calculation of volume' for proofing down.
This pic is a screenshot from my phone. It looks a bit different than the online image because he has added more calculators to it.
Higgins
Flute build
Steamer build
4 methods experiment
Aging proof experiment
Next batch: Peated Bourbon (75% Corn, 25% peated malt)
