Windy City reflux rig
- Windy City
This is what I built for running low wines to make neutral/gin/flavored spirits.
I pretty much used what I had in stock from other builds I had that were no longer being used.
I packed the column with 15 mm Siporax. This is my hope that it will behave close to SPP because 350.00$ is a lot cheaper than 2000.00$ for 15 mm SPP.
It’s a 26 gal boiler with 11KW completely controllable power, 58” x 4” packed column, (I would have loved more height but this is my ceiling height) option for Carter head before product condenser.
Following are some pics
- Windy City
Re: Windy City reflux rig
- Windy City
This is the condenser stand
- Windy City
Building the condenser base
- Windy City
- Windy City
- Windy City
- oluf
Awesome!! Looks great! How would the gin basket loop work? Won't the vapors condense on the way back up to the product condenser and fall back into the basket?
- Windy City
- Windy City
- Windy City
- Windy City
Sorry about the sideways pics guys
Mod Edit : fixed these for you Windy
... and the next couple .... from here on in , you can work put how to sort it
- Windy City
- Windy City
System has CIP for PC, Carter head in/out & packed column
- Windy City
I originally had this on a still that had three side columns.
When starting up the Carter head you have some heat loss and get some condensate,hense the ball valve to drain down the Carter head. I would try and heat up the Carter head on heads.
You can isolate the Carter head two ways 1) turn up your deflag. (Great video from Larry at Stilldragon) 2) spin your three way valves
The second option is very dependent on the operator being very conscious of your operation
- Windy City
I have “remove before flight” on anything on all my stills that need immediate attention before I start up
I have built these stills but regardless I demand a code of safety and recommend that to anyone that follows. After all that is what HD is all about
- oluf
Ahhh OK.... That makes sense. Thank you so much for responding!Windy City wrote: ↑Fri Nov 06, 2020 11:34 pmI originally had this on a still that had three side columns.
- Demy
Wow what an achievement, it looks like a mini distillery. Very good!
Setsumi
very impressive. just fantastic. is the column just packed? or do you have plates as well?
My first flute
My press
My twins
My controller
My press
My twins
My controller
- Windy City
No plates on this column.
It is packed with 15 mm Siporax.
Next to this still is my 4-plate (bubble cap) on a Bain Marie
This still is strictly for vodka, gin and neutral
hellbilly007
That is some seriously gorgeous hardware Windy
WithOrWithoutU2
That is some serious copper work.
- Halfbaked
Very nice Windy
Reason: Removed advertisement
- SassyFrass
- Location: Sittin' on the side of the Mountain sippin' and smilin'
Beautiful.
Nuff said
SF
Nuff said
SF
Real good info for New Folks:
- Windy City
I am running a modified Shady’s sugar shine today.
Really love this rig. Just wish I had built the house with a taller basement ceiling
Running at 35 amps and pulling 1.75 liters in just a hair over 12 minutes
- Windy City
- Windy City
Some more pics
This is the controller I built
- Windy City
Let’s not forget one of the most important items for your home distillery
A comfy rocking chair right in front of the still
First time checking out this thread, impressed Windy nice work!
