Will this POT suffice for a controller build?
If it plugs in, post it here.
Demy
Re: Will this POT suffice for a controller build?
Post by Demy »
Deplorable wrote: ↑Tue Mar 02, 2021 2:27 pm Sorry Demy, the first time I read your reply it didn't sink in.
I don't necessarily think the voltage reading is that important for the box's intended use. In my feeble mind, I think the bigger concern is how much current you're allowing to flow to the element. I've been reading some of the other threads as well related to the used of a course, and fine pot. So as I lay out the lid of the box, I want to me mindful of the possibility of adding a 2nd pot, or just adding a graphite resister. I don't think either addition is going to be something I will end up wishing I had done from the very beginning, but rather a future improvement in performance.
No problem, you don't have to apologize for anything. I recommended that connection because those displays show volts and also calculate watts in pase to inputs, so if you give wrong inputs you will get incorrect data. I figured if you bought that display you want that data.
Deplorable
Post by Deplorable »
It's always good the have data available.
It's going to be easy enough to move the CT. I'll likely try it on both sides of the VR. If it shuts off at very low current flow, I can always move it upstream of the SSVR.
Deplorable
I think this covers it. Please verify my connections to the SSVR, as it's always good to have someone check your work.
Looks like it will work.
Deplorable
shadylane wrote: ↑Fri Mar 05, 2021 12:53 pm Looks like it will work.
So the numbers on the SSVR connectors are meaningless? Or I just happened to get it right? 🀷
Must have been luck :lol:
Deplorable
shadylane wrote: ↑Fri Mar 05, 2021 2:31 pm Must have been luck :lol:
Good enough. I'll ground the pot and the heat sink, the check continuity on everything, and put some water in the boiler and check it all out before I use it to run my SSS. :thumbup:
StillerBoy
Post by StillerBoy »
Deplorable wrote: ↑Fri Mar 05, 2021 11:29 am Please verify my connections to the SSVR, as it's always good to have someone check your work.
From what I see in the picture, your power breaker only break power going to the element..
If that so, I wouldn't recommend setting it up that way.. the minute you plug your controller in the power outlet, your whole unit is live, not a good idea..
I build my with the power going the the breaker first, then on to rest of items..
Mars
– Albert Einstein
StillerBoy
My error on the breaker position.. sorry
It just that it's wired in reverse from what I do and the diagram on the thread I posted for you..
Mars
– Albert Einstein
Deplorable
StillerBoy wrote: ↑Fri Mar 05, 2021 5:36 pm My error on the breaker position.. sorry
Mars
My 50a in the panel is already a gfci, so I didn't see the need for a 2nd breaker, just a double pole switch.
Deplorable
Neither of the potentiometers are any good. Hooked up the first one, and it wouldn't work at all. The 2nd one was full of dead spots and wouldn't give me more than 2750w to my 5500w element.
Deplorable wrote: ↑Fri Mar 05, 2021 2:46 pm I'll ground the pot and the heat sink, the check continuity on everything, and put some water in the boiler and check it all out before I use it to run my SSS. :thumbup:
Where on the pot did you hook the ground to?
Deplorable
shadylane wrote: ↑Sat Mar 06, 2021 8:04 am
Per their instructions
I'm 99% that's wrong. Do you have an ohm meter?
Deplorable
shadylane wrote: ↑Sat Mar 06, 2021 8:23 am I'm 99% that's wrong. Do you have an ohm meter?
Yes.
First disconnect the ground from the pot and see if the controller works.
Be careful the metal shaft on the pot may be HOT.
Only touch the plastic knob
Deplorable wrote: ↑Sat Mar 06, 2021 8:37 am
Yes.
Here's how the pot is wired inside.
There should be 500,000 ohms between pins 1 and 3
The value between 1 and 2 or 2 and 3 should vary between zero and 500k as the knob is turned.
Deplorable
Yes.
Checking resistance between 2 and 3 while turning the knob slowly, indicates variations in the pot from 0.36m at the bottom of the adjustment, to ~235k in the middle, then dropping ot 0 before getting to the end of travel on one pot.
The other behaves similar on the fluke 23 meter, but the display indicated open spots on areas of travel where resistance drops to 0 then back up.
Deplorable
Both pots, are here when tested between 1 and 3
Deplorable
shadylane wrote: ↑Sat Mar 06, 2021 8:45 am First disconnect the ground from the pot and see if the controller works.
I did this last night, it made no difference. One pot worked intermittently, the other not at all
I'd take the tin can off the back of the pot and check the wiper arm.
And use a pencil eraser to clean any oil or crud off the carbon.
Demy
Post by Demy »
The connection should be done between 2 and 3. If connecting 1 and 2 the knob will lead to the contrary. The earth I don't think centers nothing with pin 1.
Deplorable
shadylane wrote: ↑Sat Mar 06, 2021 9:22 am I'd take the tin can off the back of the pot and check the wiper arm.
I've set up a return of the items. But at a cost of $5 each, what have I got to loose besides $10 and my time.
Deplorable
Demy wrote: ↑Sat Mar 06, 2021 9:26 am The connection should be done between 2 and 3. If connecting 1 and 2 the knob will lead to the contrary. The earth I don't think centers nothing with pin 1.
Measuring between 2 and 3 as shown in one of the pictures posted shows that neither pot has a reliable gradient in resistance, and neither will come close to providing 500k.
You can test the SSVR by hooking a jumper wire between pins 3 and 4 on it.
The output should be 100% when the terminals are connected and zero without the jumper.
Demy
Post by Demy »
Forgive my stupid design, perhaps it will help.
Deplorable
The SSVR worked last night when fiddling with the first pot. I could get 2750w for a time, then it was like the contacts opened on the pot, and output dropped to 0w.
The water was heating in the boiler.
Demy
Post by Demy »
Deplorable wrote: ↑Sat Mar 06, 2021 9:49 am The SSVR worked last night when fiddling with the first pot. I could get 2750w for a time, then it was like the contacts opened on the pot, and output dropped to 0w.
Have you checked the wiring above? I don't want to insist forgive me, only it seems strange for me that 2 out of 2 of those potentiometers are dead.
StillerBoy
Deplorable.. I'm somewhat sadden that you have experience failure with your controller built..
But on the other hand, you didn't followed what I advise to do. there would not have been no failure..
You seem to enjoy disregarding some good advise, and take joy in making life hard for your..
I did point out that it was wired back, but you did not get that.. that's unfortunate..
Enjoy the journey of hardship..
Mars..
– Albert Einstein
Deplorable wrote: ↑Sat Mar 06, 2021 8:11 am Per their instructions
Unfortunately their instructions were not intended for use with a SSVR and were just generic connection advise where the Pot is actually used as a Potentiometer with all three connections used .
When used with a SSRV , it is using only two of the three connections as a variable resistor .
It is unfortunate for you that they labeled one of those terminals as Ground . While this is probably a fair description in the case that it was used in a Potentiometer application , I sadly think that by you having connected it to ground , you may have burnt out both pots and possably destroyed the SSRV .
When one grounds a Pot , it is done by soldering a wire to the metal casing of the Pot or to a large washer attached to the mounting nut .
Some Pots are sold with a special 4th terminal which is attached to the case for connection of a ground wire .
You can test the SSVR simply as suggested by Shady . IE , link a piece of wire across the Pot terminals and it should run Full power . Disconnect the wire link ( nothing connected at all) and there will be zero power .
If this test works , then your Pots are burnt out .
Do be aware when measuring Pots that They have a Nominal 500kohm value due to manufacturing variations and can measure anywhere from 450k to 600k .
