What'd ya'll make today?
Re: What'd ya'll make today?
Did 2 stripping runs of HBB, now 8ish gallons of low wines. Delish
Probably another tomorrow. The rest will need to wait until it settles properly.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Simple corn and barley. Been using four sections of the Mile Hi for washes, but just two for this mash. Lots of barley in the finish, but not much corn flavor. For the next time, I'll run without any plates inside, pot style, to keep more flavor.
Brewer's Beast 16 gallon mash tun
Spike CF15 Conical Unitank
Mile Hi 16 Gallon Stainless 4 Inch Flute – 4 Sections
Very nice rig you have there
- BlackStrap
While waiting on the booners to finish fermenting...brewed up a beer today.
Decided to flake my own barley and rice from what I have around. (turned out ok... time will tell) 6 gallons went in the fermentor, 4 lbs flaked rice, 5lbs flaked barley, 16 lbs distillers malt, & centennial hops 45 min boil... SG reading 1.076
Like I said time will tell. but it sure smells good... Goal is to do 6 all grain beer's and get them in fermentors and carboy's for summer.
Seems what I give away everyone like the UJSSM back sweetened with simple sugar syrup...to about 160pr...So the brews should offer something a bit "softer" to sip around the fire.
The one who cuts the firewood gets twice the warmth
- Deplorable
Started a jar of blueberry panty dropper.
Busy weekend. I finished making up 3 bottles of panty droppers (blueberry, strawberry, and cherry) along with two bottles of cinnamon. All are ready to drink and in the fridge!
I also mashed in 12 gallons of CROB that I will run in 2 weeks.
Done it, put whole lemons in and whole limes in separate batch.The Baker wrote: ↑Fri Mar 12, 2021 6:53 pmI think maybe it would.River Rat wrote: ↑Fri Mar 12, 2021 5:41 pm I am curious about that now though. I'm sure somebody on here has tossed some whole lemons into a jar of shine before. If you cut that with simple syrup does it taste like limoncello? Sure would be easier. As long as it didn't pull some bitterness from the pith out through the peel.
I left some oranges stuck on skewers above the spirit. To flavour the spirit from the vapour....
Left them a lot too long and now I can squeeze the orange and make a screwdriver with no added spirit,
so certainly the vapour/ spirit can get into the orange, through the pith, so the pith
or its flavour probably can get back into the spirit...
2 issues: it takes up a whole lot more space so you need a lot bigger jar vs just peels where you only need to cover them.
The result did pick up some bitterness that can't be masked with simple syrup. Having said that, some of my friends loved my lime cello which was a little bitter, a piquant taste (do you like that word, its so hard to find a use for it in every day language!)
Stick with the peels.
And I left mine in for 2 weeks and longer, the peel goes white and brittle and as long as you have the pith removed, you should get a decent base for making your lemoncello.
My lime cello below compared with lemoncello.
Yes, nice outfit.
What size kettle is that and may I ask how long does it take to strip the wash.
Also, how much water?
Its time for me to upgrade from my T500, takes too long and uses a bucket load of water!
Pulled 4l of 95% neutral from about 15l of AG low wines at around 30%.
Going to have to increase the size of my mash I think, doing 6kg in 20l takes too long to accumulate enough low wines for a spirit run and then 4l is not enough to make enough gin to charge my boiler again.
Going to have to get big or get out!
It occurred to me after making that post that I had used the peels from 2.5 lbs of lemons for 1 quart of spirit (to just cover the peels). Like you were saying, a quart of spirit ain't going to cover 2.5 lbs of whole lemons....
Plain ole pot rig.
I use 15 or 16 gallon size for all three: mash tun, conical fermenter and still. Not sure what you mean by "how much water"... for cooling? I use a 20 gallon plastic trash can and a submersible 1/4 hp pump. When the water gets too warm, I dump it and refill from the hose.
Thank you, I was referring to cooling. The problem with the T500 is the water comes out at 50C plus, I tried using a pump to recirculate but was not effective.oksofar wrote: ↑Sun Mar 14, 2021 6:01 pm
I use skins from 5-6 lemons with about 1.5 litres of 95% and macerate for 2 weeks plus.River Rat wrote: ↑Sun Mar 14, 2021 2:18 pmI had to look up the definition. Looks like you found a perfect use for it!
Of course lemons are different sizes so just get a feel for it.
Hope to help out CoogeeBoy without taking away from the purpose of this thread (what did ya'll make today)...CoogeeBoy wrote: ↑Sun Mar 14, 2021 9:22 pmThank you, I was referring to cooling. The problem with the T500 is the water comes out at 50C plus, I tried using a pump to recirculate but was not effective.oksofar wrote: ↑Sun Mar 14, 2021 6:01 pm
I used to use an ice-filled cooler as a water reservoir. But six bags of ice would melt in less than 2 hours, so I abandoned that (I'd be stilling for 5-6 hours). I upgraded from an 8 gallon cooler to a 20 gallon plastic trash can. Water heats up so quickly, there is no benefit from having an insulated container.
I also got rid of my first "brewers" pump - it was weak, but even worse - not self priming. If the feed hose ever came out of the water bath, I'd have to funnel water into it to get it to start pumping again, and in a hurry!
I now use a 1/4 hp submersible pump, which simplified hose connections, and has a lift height of 27', so plenty of power to pump water to the height I need, and with the velocity to keep up with cooling. I use a "Y" barb fitting to split the pump output between the shotgun condenser and the dephlegmator with quick detach couplings and ball valves at both. I may upgrade the ball valve at the dephlegmator to a needle valve for more precise flow control, but have no issues at all with volume.
When the water in the trash can gets warm, I pull the return hoses out, and just let them drain into the woods, out the back of my barn, and fill it again with cool water from the garden hose. If you use your still inside, you could just drain the hoses into the sink. I got all these cooling pieces from Amazon, including the silicone 1/2" hose. PM me, if you have questions. Good luck!
Old pump - not self priming, and weak. New self priming submersible pump - works great! Y fitting to split water flow Quick disconnects - make disassembly for cleanup and transport easy Mini ball valve
Great setup Oksofar, and maybe not off thread, it can be my "What are you going to make today...." contribution!oksofar wrote: ↑Mon Mar 15, 2021 6:30 amHope to help out CoogeeBoy without taking away from the purpose of this thread (what did ya'll make today)...CoogeeBoy wrote: ↑Sun Mar 14, 2021 9:22 pmThank you, I was referring to cooling. The problem with the T500 is the water comes out at 50C plus, I tried using a pump to recirculate but was not effective.oksofar wrote: ↑Sun Mar 14, 2021 6:01 pm
Am going to move to bigger setup now, park the old 25l boiler and invest in something more substantial.
Thanks for your input!
- Honest_Liberty
Arancello initiation
Bottled with 72% frankenshine
Last edited by Honest_Liberty on Tue Mar 16, 2021 1:10 pm, edited 1 time in total.
Sweetfeed 100 proof for drinking white
All grain bourbon for testing my patience
Whatever else is left goes to the Homefree, because, I hate waste
Continuing on my still build. Have to fit my coil to the cooling bucket today, and also solder up the fittings from the lyne arm to the coil, and then I'm ready to roll. Will hopefully run another sugar wash as well. Can't wait!
- Honest_Liberty
First 12 gallon strip of Booner's that finished at .998 from 1.043
Wringing grains and preparing for tomorrow's second strip from everything I pull off the grains
Have some single malt to strip but have a wake to go to another person died of the covid
Stripped birdwatchers, mashed-in another batch of same. Prep for spirit run.
- The Doubler (5 gal pot w/thumper)
Run it, X. Thump it, XX. If you get 1.5, well, I think you can do better!
It's EASY to make good liquor. It's even EASIER to make bad liquor!
- Honest_Liberty
Finished first strip of maybe 10-12 gallons. Going to strip the remaining 7.5
Not really enjoying this much anymore considering how little I produce for how much effort it takes.
Oh well. Time to upgrade
I'm seriously ready for a boiler upgrade too
- Deplorable
What is yours? 8 gallon? Didnt you score a keg recently to convert?
Yes I have a keg just haven't got it welded on yet I'm a cheap assDeplorable wrote: ↑Tue Mar 16, 2021 10:49 amWhat is yours? 8 gallon? Didnt you score a keg recently to convert?
- Honest_Liberty
Stripping the rest of the Booner's, 8 gallons second run out of 19 or so. Collected 2.65 gallons at 35% first run
About to liquidate my setup for $400 and purchase a 26 gallon setup with 4" 4 plate perforated column for $1100.
Then I'm buying an agitator and I'm done with with mop wringer!!!
Mashed 15 gallons of corn and barley.
Proofed the last of my Hot Cross Bun Gin experiment. It's quite nice so there might not be much left by Easter
I'm sure next year's version will be even better.
I started a bourbon mash yesterday, resting overnight, and finishing today. 60 lbs Corn/Rye malt/Barley malt in a 25 gallon cooler (my corn cooker).
This was my first use of SebStar HTL / SebAmyl GL, and this morning the mash is as sweet as can be. Today I will transfer to the fermenter (30 gal), top it off with some cold water, and pitch the yeast.
Higgins
Flute build
Steamer build
4 methods experiment
Aging proof experiment
Next batch: Peated Bourbon (75% Corn, 25% peated malt)
Flute build
Steamer build
I'm finishing up my single malt strips today cos no work ...damn rain days cut my pocketbook but are rich in hobby time
Greened up some white dog, batch 3, a corn whiskey. Listening to Irish folk songs. Happy St Patrick’s Day!
