I will try the 3 hour mash rest on the next brew day, continue on my 6.5 gallon trial size.
Why not add some glucoamylase to the fermenter to catch any stuff that wasn't converted in the mash? This may be a better option than increasing your mash time if you're trying to keep your brew day short?
Your welcome, glad it helped someone.higgins wrote: ↑Wed Nov 03, 2021 7:09 am
The initial drain off was low and slow, and afterward I noticed a fair amount of cornmeal packed around the SS braid. Next time I'll leave out the drain manifold until ready to drain, then scoop out the mash, install the manifold, then add the mash back before draining. This was a long day, but it didn't require my full attention so I was able to multitask and get other things done too.
For some, “calculation” is easier than “stumbling & fumbling” on brew day. I too, prefer to “pre-calculate” my infusion steps and water thermal loads before mashing to better focus my efforts on brew day towards the physical tasks of the day. It makes the process a lot less “potluck” and much more “predictable”.
YOU could, and others would. But, to some the brew day process is as much a part of the hobby as is the day of distillation. For a dedicated homebrewer in this hobby, the mash and process is an important component of “the reward”. It is “a part of the art”.squigglefunk wrote: ↑Thu Nov 18, 2021 7:23 am… you could just get some of that yellow cake angel yeast … dump all the crap into a big container … and do nothing!
Well stated, and I agree. For me, Angel yeast yellow leaves a flavor I'm not really fond of, you find it in things like sake and kimchi. I would rather just make ujssm or some other sugar base.still_stirrin wrote: ↑Thu Nov 18, 2021 7:46 am
As for the “yellow Angel yeast”, it can be a good recovery “catch all”. But it may not be what every hobbiest prefers to use. You can use a mop to clean up a messy floor, but wouldn’t it be better to not make the mess to begin with?
Bens on it ..use less backset, Ive done 9-10 years worth of UJ, generation after generation, still on the original yeast from the very first Ferment.......never once had to adjust PH or start off again. If your ferments are slowing your using to much..that simple.BrewinBrian44 wrote: ↑Sat Dec 04, 2021 8:46 am I use it in ujssm when I’m doing many generations of sour mash. Works great!
