How to degas and open a sanke type keg
a video describing how you open and degas a keg:
http://www.youtube.com/watch?v=3G7Ypf5Ojno" onclick="window.open(this.href);return false;" rel="nofollow
Whiskey, the most popular of the cold cures that don't work (Leonard Rossiter)
Re: How to degas and open a sanke type keg
I think this has already been posted once somewhere here. But it's good info.
not this vid
i did a search and didn't find anything much so i thought id make a video of how i do it
Description here:http://homedistiller.org/forum/viewtopi ... &sk=t&sd=a
Never refuse to do a kindness unless the act would work great injury to yourself, and never refuse to take a drink-- under any circumstances.
- Mark Twain's Notebook
Ah, good then. I thought I had seen a video but it must have been photos that I saw in that thread.
Sorry for my mistake.
Hi all,
Well I have a newly acquired european style sankey keg, they do not have the 2 notches as your US style sankeys would have, mine is like in this video.
2mins 17secs to 2mins 31secs is my problem, I already unscrewed it but there is a clip holding it in. Bloke in the video says you need to push the spring all way down, well a coupler may do that.
I am thinking that the spear would just pull up if I used a coupler to attach, has anyone tried this, I don't want to buy a coupler if in the end I convert to another fitting, plus the spear is as good a fit as is possible for tapping liquid from it?
This is not for boiler use, but liquid storage so I want to keep the spear and use a couple of John Guest fittings on a sankey coupler. However I still want to remove the spear for a good cleaning.
- Salt Must Flow
Do you intend to keep all of the internal components and use those parts to dispense stored product through it? I'm just a bit confused as to what you intend to do exactly. I usually throw the spear and those parts away.
For storage, I just use a Tri-Clamp end cap with a PTFE gasket grind/sanded flat on one side and a clamp. For dispensing there are many different ways, but I'd rather first hear what your intentions are.
Hi Salt, Yes I wanted to use those original parts for dispensing product.
I had thought about using the intended coupler and a gas line as the easiest option.
A tri clamp adapter is also an easy no weld option, but then your starting to move the keg for dispensing.
- Salt Must Flow
I'm pretty sure there are rubber seals in that valve that would not be approved for high proof product.Hebden wrote: ↑Wed Jan 04, 2023 12:56 am Hi Salt, Yes I wanted to use those original parts for dispensing product.
I put together this setup with a standpipe to dispense out of a keg. I connect an air line from an air compressor, crack the valve and product exits the keg. I still need to install another valve on the outlet, but it works great. It's completely modular so there's no need to modify a keg at all. All it needs is just a gasket & clamp. I mostly only use this for transferring low wines from a storage keg to the boiler for all feints runs. For primary storage I use 1 gal glass jugs with a cork. I find them cheap at local junk shops, yard sales, etc... Glass carboys are handy too.
If it is an S type sankey, it looks to be. Unscrew the spear, place a coin that fit into the opening and use the coupler to press down. The only ones I vould not open that way were from Namibian breweries.Hebden wrote: ↑Tue Jan 03, 2023 5:03 pm Hi all,
My first flute
My press
My twins
My controller
My press
My twins
My controller
