3" CCVM
ecir54
3" CCVM
Early on during the pandemic put this together. Was planning on using spp but the war messed up the source i used before so put it aside. Wasn't crazy about the stainless tee and long radius elbow so watched ebay to find a copper tee as street elbow at reasonable prices and in the mean time contemplated which media to use. Came across bushman's thread on making copper packing and i had a bunch of welding lead so said why not give it a go and decided it was time to move this project further.
3 pieces #1 wire 3'
3 pieces 5' still needing to unravel
3 pieces #1 wire 3'
Setsumi
Re: 3" CCVM
Just a heads-up. If you have not installed the sight glass yet place it lower than the take-off. All you will see there is reflux dripping. Top of the packing is what you want to see.
My first flute
My press
My twins
My controller
My press
My twins
My controller
- Salt Must Flow
Re: 3" CCVM
He has a sight glass just below the takeoff. Not sure what you are trying to say. He also has one at the base of the column. I'd say he's golden when it comes to sight glasses.
- Salt Must Flow
Setsumi
Re: 3" CCVM
Second picture? The changes he is talking about?Salt Must Flow wrote: ↑Fri Apr 21, 2023 8:46 pmHe has a sight glass just below the takeoff. Not sure what you are trying to say. He also has one at the base of the column. I'd say he's golden when it comes to sight glasses.
Okay, I did miss the first pic.
Still if you do a sight glass like the old school ones that is fixed to the column, place it lower.
Iamnotmoduler
My first flute
My press
My twins
My controller
My press
My twins
My controller
- Salt Must Flow
Re: 3" CCVM
Setsumi wrote: ↑Fri Apr 21, 2023 9:02 pmSecond picture? The changes he is talking about?Salt Must Flow wrote: ↑Fri Apr 21, 2023 8:46 pmHe has a sight glass just below the takeoff. Not sure what you are trying to say. He also has one at the base of the column. I'd say he's golden when it comes to sight glasses.
Iamnotmoduler
ecir54
Re: 3" CCVM
still dragon sight glass is to see position of reflux coil, inline sight glass is to see top of packing
will need more 3" cu to play with height later.
Setsumi
Re: 3" CCVM
Maybe today with moduler setups, it was not always like that.
There was a time when all sight glasses were fixed to the column as windows. And there was a time that sight glasses were DIY before StillDragon glasses.
But I am being pedantic
My first flute
My press
My twins
My controller
My press
My twins
My controller
Wildcats
Re: 3" CCVM
Looks great. Now you got me thinking about a sight glass in my tee.....
ecir54
Re: 3" CCVM
yes times have changed, here is one form awhile back
kimbodious
Re: 3" CCVM
I agree that your column is going to need more length.
Will the new offtake configuration involve triclamps? I like having the ability to change the angle of my product condenser on my CCVM
Modular 2" Pot Still
ecir54
Re: 3" CCVM
yes have tri clover ferrules but more so to keep all parts modular pooling would be a problem with a shotgun at a angle.
Laredo7mm
Re: 3" CCVM
My initial gut feeling is that a shotgun condenser at an angle shouldn’t be an issue. It is all vapor going into the condenser so it should be evenly spread across the inlet even if it is at an angle. There might be a difference in the water flow through the shotgun, but I don’t think it would be an issue. My LM still head has its reflux condenser at a 45 degree angle and I never saw an issue when running it.
ecir54
Re: 3" CCVM
well it all depends how close the vapor tubes are to the wall of the condenser will determine if there is a chance of smearing. any design that allows smearing would be a negative in my book it's why using a parrot isn't recommended to be used throughout a run.
- Salt Must Flow
Re: 3" CCVM
Try holding your shotgun at a 45 degree angle and pour a bunch of water through it. Now pour out any water that 'pools' inside it and you'll see that it's only a ml or so. Even if anything did pool, it would be insignificant. A parrot is a totally different story because of the volume it holds. During a stripping run, parrots are fine. It's spirit runs where it could smear.ecir54 wrote: ↑Sat Apr 22, 2023 4:31 pm well it all depends how close the vapor tubes are to the wall of the condenser will determine if there is a chance of smearing. any design that allows smearing would be a negative in my book it's why using a parrot isn't recommended to be used throughout a run.
ecir54
Re: 3" CCVM
Might need another sight glass to confirm
kimbodious
Re: 3" CCVM
The input side of a product condenser is the “hot side” I doubt if there’s any condensate there during a run. There would be condensate there once the vapour column has collapsed say when power to the boiler is shut off. That condensate would be low purity if it was at the end of the run. I think people are aware of the condensate and believe it is there during the whole run.
ecir54
Re: 3" CCVM
i hear yall preserving some product and enjoying some rare breed tonight
ecir54
Re: 3" CCVM
anybody know how long of a piece of 3/8 refrigeration soft copper would be needed to do a double wound reflux coil around 10" in height?
ecir54
Re: 3" CCVM
^^^ diameter x pie x number of rows should get me close.
Had time this weekend to fit the ferrules. the street elbow was pretty thick so had to take quite a bit of material to get a hand tight snug fit.
the 3" the stainless ferules fit loose in DMV pipe and are too big for type m pipe. used type m for the sleeves in the tee and again took material off for a hand tight snug fit. this should make it easier to square the ends before soldering which would have been a pain to deal with with a loose fitting ferrules.
DMV 3.030 id
type m 2.981 id
stainless ferrule 3.011 od
DMV 3.030 id
type m 2.981 id
Wildcats
Re: 3" CCVM
Looks good. You will be happy with that. I like the flush fit of the ferrules. I did mine the same. I like it!
Have fun and stay safe.
ecir54
Re: 3" CCVM
thanks, just finished fitting this 2" ferule for the sight glass. nice and snug that needs a tap with a rubber mall to go into place. just need to trim the back side of the ferrule.
ecir54
Re: 3" CCVM
finished the rough cut on the 2" ferule next will be the fun part of trying to do a double coil 3/8 refrigeration tubing rc.
Wildcats
Re: 3" CCVM
Plenty of good stuff on winding coils on here. I tried to use 3/8" tubing. But I ended up using 1/4". Let us know how you get along with your coil. Spring benders are a great help.to make that first and last bend. I found 1/4" a lot easier to wind than 3/8". Good luck.
ecir54
Re: 3" CCVM
Hey wildcats have done coils in the past with good results all double row. one for 1 1/2" and 3" with 1/4 refrig tubing and one for 4" with 3/8 tubing. Was never happy with the flow restriction on the 3" with 1/4 tubing being using a pond pump for flow so am going to attempt a 3" with 3/8 tubing. The outer coil shouldn't be a problem, going to be tricky to do the inner coil with 3/8 tubing.
- Salt Must Flow
Re: 3" CCVM
It's all about the mandrel size. This topic comes to mind where Hebden wound his first coil (3/8" if I recall) for his 3" VM. Filling the tubing with salt is extremely helpful in my experience.
ecir54
Re: 3" CCVM
thanks for the link have two pieces a pipe set aside, will compare the sizes later when get home to what Hedben used.
OtisT
Re: 3" CCVM
Another helpful item for making 3/8 coils if you are worried about kink issues would be to use 3/8” elbows. They can help join two single coils and/or help anywhere you have a tight bend.
I made 3/8” copper double coil, independent I/O, dephleg/RC for a 4” column. Those little elbows made the fabrication process way easier than trying to bend everything and with no kinks, the flow rate was way larger than I would ever need. If you want to see pics of how i used the elbows, just ask and I’ll add a link here.
FYI - with 10” of coil height to work with, a single coil of 3/8 tubing is enough to easily handle 5500W.
ecir54
Re: 3" CCVM
^^^ yes that the plan also going to use a 1/2 pipe down the center to feed water to both coils from the bottom.
wouldn't have thought single 10" 3/8 would be enough to knock down 5500 watts, thanks for the info.
Wildcats
Re: 3" CCVM
Subscribed. Can't wait to see what you come up with.
