Is it really a reflux?
jdthedj10
Hey guys, been out of the game for about 15 years so I'm coming back in and trying to re-immerse myself in the art. Been doing a lot of reading trying to remember lots of things and one thing that I cannot find is driving me nuts here.
I have attached a photo of the column that I built. When I used it I kept it full of copper mesh basically from top to bottom. The column is approximately 42 in high before it turns. This time around I wanted something with more flavor in it so decided to pull all of the copper mesh out. Then I did a little more reading.
It seems that it's not a true reflux still unless it also contains a dephlegmator in conjunction with the packing. I do know without it I can pull off 180 with just the packing and keeping the valve closed during equalization. I have recently decided to put another valve in the drip line that goes back down the column. My thoughts on this is to remove my packing, close off the valve running back down the column, and only open the drip valve.
If I do this do you think I would get more flavors? My only concern is maybe I need enough packing to help remove some of the off flavors. I also may need it to go into reflux for an hour or two to increase the overall proof before opening the outlet valve. I hope my rambling is didn't confuse anybody and maybe somebody can give me some insight on this. What are your thoughts?
- Salt Must Flow
Re: Is it really a reflux?
What you built is an offset LM (Liquid Management) reflux column. The vapor rises up through the column, is condensed by the reflux condenser and the take-off rate is adjusted by that little needle valve. The rest of the falling reflux passes through the other copper tube and falls onto the column packing. Yes that is a true reflux column. No, you do not need a dephlegmator, you already have a reflux condenser (though I cannot see it in the photo).
You could remove the packing and operate your still in 'pot still mode'. People here with more experience doing that may have some input operating a LM in pot still mode. Another option is to install at least one set of Tri-Clamp ferrules (either copper or stainless) just beneath the LM return tube. That would allow you to remove the reflux head and use your copper column as a riser. You can easily put together a simple pot still head (elbow & reducer) which can connect to a product condenser (like a Liebig Condenser for instance).
jdthedj10
That's a great idea about adding the tri clamp ferruls! Thank you. OK I'm going to keep the packing out on this run and keep the take off valve open. Thanks for the input.
I did a few experiments with tall packed risers and on a stripping run , there was almost no perceivable difference with having the it packed or unpacked , wrapped in insulation or not ( getting passive reflux due to heat loose to the surrounding air) .That was at 2400w .
If you are doing a spirit run , you would likely be using less power but if you keep the column insulated , and packed , you should still be able to get sufficient separation for foreshotes and early heads removal . Then open the takeoff and run as a Pot still for a flavoursome hearts .
Nit sure what drink you are trying to make but you should have quite some control over how much tails smear comes over in your hearts as you desire by backing off takeoff rate (closing the valve a bit)
- Stonecutter
No it ain’t no reflux. You’re either sending shit back down the pipe in a controlled manner or you’re not.
-Thomas Paine
-Thomas Paine
Sorry stoney but it is .Stonecutter wrote: ↑Fri Oct 13, 2023 6:36 pm No it ain’t no reflux. You’re either sending shit back down the pipe in a controlled manner or you’re not.
It’s a Nixon Stone offset reflux still . It was a common design about 15-20 years ago .
The original design was a dual valve job with the second valve in the reflux return line , but it was found ti be not really needed so folk just omitted it.
There is a reflux coil in the offset section . The condensate collects in the cup at the bottom . What isn’t drawn off as product returns back to the packed column as reflux.
But I guess you are right that if you are collecting all as product , then there is no reflux so it can’t really be called a reflux still at that point .
- Stonecutter
Thank you Yummyrum. Looks like a great opportunity to read up
-Thomas Paine
-Thomas Paine
Non worries Stoney .Stonecutter wrote: ↑Fri Oct 13, 2023 7:09 pmThank you Yummyrum. Looks like a great opportunity to read up
Here’s a couple to get you started .
There used to be a website that had full plans you could download to build one but it seems to have gone
viewtopic.php?p=6827711#p6827711
viewtopic.php?p=6837699#p6837699
- NZChris
I've been waiting for someone to point out that it needs a deflegmator to prevent the product escaping out of the top. Maybe I'm wrong, or don't understand the pic?
Do you have a bit of wound copper tube that will fit into the top of your riser in your stilling cupboard?
Good point NZChris . I saw it missing in OP but didn’t think to question it . Just assumed it was part of the kit .But certainly after 15 years it could have gotten miss placed or forgotten .NZChris wrote: ↑Fri Oct 13, 2023 10:19 pm I've been waiting for someone to point out that it needs a deflegmator to prevent the product escaping out of the top. Maybe I'm wrong, or don't understand the pic?
Incidentally it would be called a Reflux condenser . Deflegmators are used in CM stills . This one is Liquid Management .
- NZChris
Call it a reflux condenser, deflegmator, whatever you like, it still has to have cooling to cause reflux, which is often water in a coil.
It's a reflux coil/ condenser......the job of a deflegmator is to only partiality condence the vapours rising up the column.
SBB by definition your answer is correct.Saltbush Bill wrote: ↑Sat Oct 14, 2023 2:41 am It's a reflux coil/ condenser......the job of a deflegmator is to only partiality condence the vapours rising up the column.
I have a shotgun dephlegmater and I can get 100% reflux until I tune it down for collecting. Thus like NZ I probably interchange the terms.A dephlegmator is a device arranged for the partial condensation of a multicomponent vapor stream. The vapor stream flows vertically upwards and the condensate (condensed vapor) runs back down under the influence of gravity.
- Stonecutter
Great linksYummyrum wrote: ↑Fri Oct 13, 2023 8:02 pm Non worries Stoney .
I’m pleased with the CCVM design. Super easy to build. Maybe not as easy to operate as the boka or other VM designs.
The pursuit of a fine drop continues.
Have fun and stay safe
-Thomas Paine
-Thomas Paine
drmiller100
As a side note I control the reflux only and collect the overflow.. with this I didn't have to change anything As the wash lost proof.Yummyrum wrote: ↑Fri Oct 13, 2023 6:49 pmSorry stoney but it is .Stonecutter wrote: ↑Fri Oct 13, 2023 6:36 pm No it ain’t no reflux. You’re either sending shit back down the pipe in a controlled manner or you’re not.
Sounds like you were running Reverse LM Dr .drmiller100 wrote: ↑Sat Oct 14, 2023 3:39 pmAs a side note I control the reflux only and collect the overflow.. with this I didn't have to change anything As the wash lost proof.Yummyrum wrote: ↑Fri Oct 13, 2023 6:49 pmSorry stoney but it is .Stonecutter wrote: ↑Fri Oct 13, 2023 6:36 pm No it ain’t no reflux. You’re either sending shit back down the pipe in a controlled manner or you’re not.
That is one of the advantages of it . It’s sad it never really took off .
