I have been doing a lot of research over the past few days. Here is my design for a valved reflux still. This is just a quick CAD sketch. It will be built out of stainless steel tube salvaged from a dairy farm. I'm not 100% sure of what material I have to work with but i will update it when I'm sure. I have a few questions on this design. Should there be a cap/vent above the coil on the condenser or at the top of the tower? How far down should the reflux line return back to the tower? I would rather have my design critiqued before i build this still rather than after.
Valved reflux still design?
GeneralLee
Ayay
Re: Valved reflux still design?
Yer close, Bokakob got the coil on top and only one valve is needed. Slant plates can be replaced with a cup or a collar.
Your design will work fine but there are ways to get the same result with less outlay.
Welcome to the forums, GeneralLee...
As noted by Ayay, the Bokakob dual slant plate design is cheaper to build as well as easier to build and operate... It's not that your offset head valved reflux design won't work, it just takes a lot of extra fittings and fussing to do what a far simpler design just quite well... The Bokakob dual slant plate design is simplicity at its best which is why it is favored here in the forums for a Liquid Management design...
Either copper or stainless steel can be used for building a still... Copper is easier to work with but stainless steel is slightly more durable and adds some "Wow" factor while not adding to overall performance... You definitely need copper somewhere in the vapor path so if you go with SS you will need to use copper structured packing in the column...
Good luck...
Good luck...
GeneralLee
The only materials I will need buy would be tubing for the coil, a thermometer and maybe a fitting or two. I am going to tig weld everything so i will not need any other stainless fittings. The one big question I have about this design is how does the pressure escape? could you run this design with an open top? I was thinking about loosely fitting a cap over the coil so the coil can be removed.
WalkingWolf
Howdy GeneralLee and Welcome to the forums,
To answer one of your questions? Pressure = BOMB
The still should never be sealed. You must have adequate cooling to knock down all vapor. Keep reading, you will come across this info. as you progress. Use the search function at the top right and search for "pressure bomb" and you will get enough information to clear it up.
Good Luck and Welcome
WalkingWolf
WalkingWolf
+1 on what WalkingWolf said, GeneralLee...
With a pot still or Cooling Management reflux column the vapor always has an unimpeded escape route through the worm/liebig condenser... With Liquid Management and Vapor Management reflux columns there should always be a vent above the reflux condenser because the reflux condenser should always be capable of knocking down 100% of the distillate vapor produced...
The best advice, as previously mentioned, is to make sure you fully understand the theory behind the various types of stills, and distillation in general, before proceeding... Safety cannot be stressed enough when dealing with such highly flammable and even explosive substances as alcohol...
