Pressure controlled quick connect fitting
Tammuz
Post by Tammuz »
I have a flow meter on my condensers I was planning on using these for finer control at each condenser.
Has anyone used these?
Salt Must Flow
Re: Pressure controlled quick connect fitting
Post by Salt Must Flow »
I've never used those valves, but I've seen them sold with China stills and everything I've read says those pneumatic fittings & valves can also be used with water. Many of the specs I've seen show the max temp range as 60C/140F, but that's likely max 'operating temp' at 110psi (or higher) and a somewhat conservative figure.
I've always used brass needle valves for water control, but those are inexpensive enough to replace if anything ever failed. They should work just fine.
Out of curiosity, what flow meter are you using? I've always used a thermowell and a needle valve with each condenser that way I can tune the water flow to not exceed a given temp. To determine the flow rate, I have to collect X amount of water and time it.
higgins
Post by higgins »
SMF, Here is what I use:
Flowmeter 100-1000 ml
Higgins
Flute build
Steamer build
4 methods experiment
Aging proof experiment
Next up:
Bourbon (71% Corn, 19% flaked rye, 10% malt, pot stilled)
Single Malt (74% pale malt, 22% vienna malt, 3% crystal 10, 1% chocolate)
I used to have flow meters like that.
Worked great until freezing weather and I forgot to drain the cooling water. :lol:
The actual flow didn't match the measurement, but it was consistent.
All I had to do was open the valve until the little ball was at the ink mark I drew on it.
Industrially, I've used hundreds of those fittings in pneumatic applications without any problems. They require pressure to seal so I've never bothered to try using them for low pressure/flow water applications in my distillery even though I have them available.
Thumperbunny
Post by Thumperbunny »
Da kwik connects work fine. Prolly one of da best I had used.
Tammuz
Post by Tammuz »
I have some nice needle valves but when I saw these I figured I could cut out a few connections. They will be here in a week I'll let you know what type of control they have.
This is the
Meter which has no restrictions other then the control knob.
