Filter issue
Ncreasy
Filter issue
Post by Ncreasy »
Ran a sugar wash this morning (one of 2) and decided I wanted to filter, never have before but wanted to see what the difference would be, followed G ****** preference on his one video of using a zero water brand filter, brand new never used with water. Well I poured 800ml through... I lost 9% ABV and it came out with a yellow tint??? Like a significantly yellow tint.... thought maybe somehow this was a fluke, maybe because it was a brand new filter, so I took another 800 ml jar and tried again and got the same exact result. Loss of 9% ABV and heavy yellow tint... fortunately for me I have another sugar wash ready to distill and I'll just treat everything from this as a stripping run, but what gives?? Why did this happen so I can avoid in the future. Obviously if I'm going to filter I'm not using that strategy again
acfixer69
Re: Filter issue
Post by acfixer69 »
Do not use a made for water filter. This is why George is banned here. His info is mostly wrong.
Re: Filter issue
The use of that name is banned from this forum.
He gives more bad than good advice.
Please read our rules carefully
Edit.
Posted at same time as AC.
Dancing4dan
Re: Filter issue
Post by Dancing4dan »
Ethanol is a pretty good solvent and will dissolve plastic water filters resulting in contaminated product.
Develope and stick to good fermenting and distilling protocols and you won't ever need a filter.
Marcus Aurelius
Ncreasy
Re: Filter issue
Post by Ncreasy »
Saltbush Bill wrote: Sat Feb 15, 2025 12:23 pm The use of that name is banned from this forum.
Ah I didn't see that his channel is flagged on here down at the bottom of the rules. My apologies
Re: Filter issue
Agree with all above . About filtering .if you are going to do it you should use activated carbon .
Dilute to 50% abv first as it is apparently most effective then .
I agree with D4D that the high abv ethanol would have been dissolving some plastic in the filter .I would not use that type of filter . You are better to get a SS , copper or glass container , fill it with carbon and put a small tap on the bottom to let the alcohol slowly drip through .
