Concentric Build
Post your builds here.
thisguy
Re: Concentric Build
Post by thisguy »
I did a run last night and actually kept track of what was happening, heres the log...idk if its going to be what your looking for...
I ran it with the cold finger. And the wash never finished fermenting cause im experimenting with corn syrup solids and have screwed up the last few ferments.
After heat up:
35 mins in: 250ml @ 150p
60 mins in: 250ml @ 144p
95 mins in: 250ml @ 128p
118 mins in: 250ml @ 100p
148 mins in: 250ml @ 72p
170 mins in: 250ml @ 50p
190 mins in: 250ml @ 40p
End
Total in Liters: 1.75L
So turns out the post above was way off in times and everything. I was excited and over estimating everything. Either way though, Im happy with the results, even though it did take me over 3 hours to get that out of a 5 gallon setup. But that does not matter, when I still, I dedicate the whole day to it. As far as cooling goes, it still works great, the cooling water never gets too hot, and the cold finger stays barely warm, the condenser has a nice even temp gradient. Im pleased with the design.
Lighting new cigarettes
Pouring more Drinks
It has been a beautiful Fight
Still Is
Work hard and say its easy...Cranky's Spoon Feeding
Concentric Still Build
Chauncey
Post by Chauncey »
Is it just me or is this still lacking atmosphere vent
fzbwfk9r
Location: Smack Dab in the Middle of God's country. Saskatchewan!
Post by fzbwfk9r »
Chauncey wrote: Thu Sep 19, 2024 10:08 pm Is it just me or is this still lacking atmosphere vent
The cold finger is just a loose fit in the top, room for pressure to escape around it.
Dancing4dan
Post by Dancing4dan »
Not sure of the overall dimensions of your concentric condenser but I can’t see needing a cold finger in it. As others have stated that would be counter productive.
My concentric is 14 inches tall and on a LM/VM combination still head can produce 1000 ml every 15 - 20 minutes on a 2” column 48 inches tall. At that speed the reflux condenser is still knocking down all vapor.
If the concentric isn’t knocking down all of the vapor you could try extending the top of the eccentric and putting the cold finger in the extension. I would extend the outside size tubing to decrease vapor speed.
Marcus Aurelius
Dancing4dan
thisguy wrote: Sat Jan 31, 2015 4:51 pm As far as cooling goes, it still works great, the cooling water never gets too hot, and the cold finger stays barely warm, the condenser has a nice even temp gradient. Im pleased with the design.
I find reflux works better if cooling water is warmer. This results in the condensed ethanol falling down the column being warmer.
Think of it like this. If what falls back into your packing is to cold it will cool things off to much causing everything in the column to condense and fall back to the pot. Where it has to start over rather than refluxing in the column.
Marcus Aurelius
