Help! My element scorched - but how? What happened?
- Salt Must Flow
Re: Help! My element scorched - but how? What happened?
If reducing power to 50% helps, it might warrant installing a 2nd element in the future. Two identical elements operating at 50% should be the equivalent of operating one element at 100% power.
beta-glucanase can help with your rye in the mash.
- higgins
Looks like the forum is running good again
I've done 2 100% flaked rye mashes in the past year using YLAY
15.5 keg, 5500w element, inline sight glass at bottom of 2" riser, 2" x 20" shotgun condenser
Stripped the (not very clear) beer by heating fast at full power, slowed down when foam showed in the sight glass, then as the foam resided I ramped it up, ending at full power. About 4 hours to do two 7.5 gal runs (1st run preheats 2nd, 2nd preheats 3rd. I also degas by power stirring during preheating).
Stripped the slurry using steam, another 3 hours.
Spirit run heated fast till near drips, then slowed to about 12% power. Once in hearts I go to 15%, tails 50%.
Neither had any hint of a scorch, and my element is clean. Its possible that YLAY breaks down whatever collected/burned on your element.
Higgins
Flute build, Steamer build
Next up: Irish Style Whiskey
- Bee
Maybe try some ViscoSEB L beta-glucanase enzyme. I believe that is made for rye "slime".
1) I figure you already see the problem.PalCabral wrote: ↑Sun May 04, 2025 2:32 am
Mashing: I've done 6 AG ferments for Bourbon so far without issue. However, there were two differences between this one and the previous batches:
1) the mash in question had a recipe that contained +30% malted rye, in place of malted barley and malted wheat in the pervious 6 mashes....
2) I was sparging much more this time, to extract as much fermentable sugar as possible from the malt bed.
Even with a good protocol, "rye slime" coated the element and started the scorch.
2) That ain't the problem, more like a good idea to avoid what happened.
For whiskey, I like the idea of fermenting off the grain and using plenty of sparge water. Nothing wrong with extracting all of the fermentable sugar and having a lower original gravity.
- PalCabral
I've looked for ViscoSEB L and Sebstar L but found very few suppliers that sell it, and the one that do, ships to Europe for $163 (the 4oz container cost $15) - UPS will never get that kind of money from me for a such tiny job. A search for Beta Glucanase also gives a Chinese supplier (Ali) that seems to sell the same type of product, but as usual the English translation is so poor it could just as well be horse stool pills they are selling. Not really sure I want to buy any of the obscure "enzyme" products for sale on ebay et al when the descriptions on the products are so vague.
In yesterday's brewing (the same recipe) I increased the length of the beta glucanase (43C) and protein rests (50C) to 15 minutes each, I am hoping these changes to procedure will have some effect on viscosity forming during fermentation, as I don't have viscosity issues in the mashing process.
But what about YLAY? Higgins raises an interesting question, does YLAY contain beta glucanase which handles the issue with viscosity and "rye slime"?
- PalCabral
Yes, thanks, Shady! I see the problem but perhaps not yet the light
- PalCabral
Yes, I will probably want to go down that line. The boiler has ports for two element, so it can be arranged.Salt Must Flow wrote: ↑Sun May 04, 2025 11:16 am If reducing power to 50% helps, it might warrant installing a 2nd element in the future. Two identical elements operating at 50% should be the equivalent of operating one element at 100% power.
