Support your column
Setsumi
Support your column
Post by Setsumi »
I hate long posts, try to read to the end. My boiler for the last 6 years is a copper geyser or hot water cylinder for some. I soldered a 54mm (2 inch) slip coupler and triclamp ferul on top of the dome. I run a 5 plate home build flute or plater in either perfs or caps. It has some weight either way. I run electric.
A few runs back I noticed the flute leans a bit to the collection side but thought the boiler got bumped when empty and repotioned the boiler to fix the lean.
So, yesterday I fire up at 6 am and are collecting fores at 7:30. 300ml in the column just go 30 degrees to the condenser side. Steam is leaking a bit from the ferul but the triclamp is good. Luckily I have my trusted stilling towel to keep me from burning my hands while I support the column.
Now I am in a tight spot. To kill the power I have to move 2 steps from the still but I cannot let go of the column and I do not want to get burnt by steam.
In the end I pushed the column 180 degrees to rest against the garage door and managed to kill the power to the still.
After inspection the reason is obvious. Heat softens copper, my flutes are too heavy for a thin copper geyser. I need support for the column.
Outcome, I lost a ferment of 20kg maize meal.
Warning, support your column.
To do, if you see something is different find the reason.
My first flute
My press
My twins
My controller
Copperhead road
Re: Support your column
Post by Copperhead road »
Years ago i was going to try turning in an old hotwater heater into a boiler, i canned the idea after i did a forum post asking for advice.
2 issues arose, 1 was they are prone to pin hole leaks and 2 they are to flimsy to support a full copper 5 plate 4" bubbler. :crazy:
PalCabral
Post by PalCabral »
Scary moment, I am sure. Good thing you're on electric, with gas heating it could quickly escalated to catastrophic.
How did you lose you mash, Setsumi, you couldn't save what was still in the boiler?
Corn Cracker
Post by Corn Cracker »
That sux man, I've about got my 3 inch type K copper column complete and it's a heavy beast, the 3x15 inch shotgun is my main weight concern and I still have the triclamp ferrules to add to it. My next step is support for it
BigSwede
Post by BigSwede »
Sorry to hear this.
It'd look weird, but on the side opposite the product condenser, perhaps have some weight to even out tilting stress on the column/boiler interface? Lots of materials do fine in compression if the force is evenly applied. But a Leaning Tower setup, not good.
Setsumi
Post by Setsumi »
PalCabral wrote: ↑Sun Oct 04, 2026 12:13 am Scary moment, I am sure. Good thing you're on electric, with gas heating it could quickly escalated to catastrophic.
Ja, I could transfer the mash but this was my last run at this property. In 2 weeks time I off for a medical procedure and then I will move my brewerey 850km to a new location. Nope I am done for a while.
My first flute
My press
My twins
My controller
Corn Cracker
Setsumi wrote: ↑Sun Oct 04, 2026 4:53 am
Good luck with that, looking forward to hearing about it when you healthy and set back up in a new place
lunarotter205
Post by lunarotter205 »
Glad this was caught early. A plated column puts a lot of leverage on a single soldered joint, and a hot water cylinder dome is thin copper that softens with every heat cycle, so a slow lean is a typical warning sign. Supporting the column independently of the boiler, with a bracket or strap to a wall or a simple frame, takes the load off the joint. The steam leak at the ferrule also points to the joint moving rather than the clamp. Checking the column for plumb at the start of each run is a quick habit worth keeping.
