Wiring question
If it plugs in, post it here.
pointhunter75
Re: Wiring question
Post by pointhunter75 »
Thanks for the Info! My bung is already welded in. Just gotta get the plug wired and controller built. I'll have more questions for you I'm sure.
pointhunter75
Re: Wiring question
The closed circuit meter is the correct one rgreen?
rgreen2002
Re: Wiring question
Post by rgreen2002 »
https://www.amazon.com/gp/product/B00YY ... UTF8&psc=1" onclick="window.open(this.href);return false;" rel="nofollow
That's the meter I picked up. It is a closed circuit transformer
HD Glossary - Open this
skow69
Re: Wiring question
Post by skow69 »
$17. Amazing. I couldn't resist. Mine is on order.
rgreen2002
Re: Wiring question
skow69 wrote:$17. Amazing. I couldn't resist. Mine is on order.
I like that meter skow... like pointhunter75 said...pretty damn cool looking!
papapro
Re: Wiring question
Post by papapro »
Also you can use an old computer power supply on the main plyg to the mother board look for green wire cut it and get one of the black and short it together.
Once power it up you will have 5V DC on red and black and on yellow and black will have 12 VDC.
colors are red 5V ,yellow 12 V , black ground.
PapaPro
Yes I am a Novice with 40+ years of doing this hobby
distilling is like sex the slower the better and everyone is happy
fermenting is opposit to sex the faster the better
ddizzle22
Re: Wiring question
Post by ddizzle22 »
I built my controller exactly like rgreen added a 240v light indicator as well as a 240v fan in the 8x8 home depot box. Works great. I followed the wiring exact like rgreen my thread is somewhere in here.
squeezins
Re: Wiring question
Post by squeezins »
I bought a cheap 12v power supply and mounted it inside the box. I think it was $8 on eBay. I can't edit pics on my phone but you can see it right in the center. [img]http://uploads.tapatalk-cdn.com/2016120 ... dd3abf.jpg[/img]
Experience is something you don't get until just after you need it.
pointhunter75
Re: Wiring question
Pc fans are 120v Correct?
Snackson
Re: Wiring question
Post by Snackson »
pointhunter75 wrote:Pc fans are 120v Correct?
There are plenty of different voltages available. 240, 120, 12dc, 24dc, etc.
papapro
Re: Wiring question
Post by papapro »
The power supply for PC is switchable 120 or 240 but the fans are usual 12 v are you talking the fan on the processor or in power supply.
on Power supply is wired internaly and most likely is 12v also.
Regards
PapaPro
pointhunter75
Re: Wiring question
Oh didn't know that. I guess was talking about power supply fan. Forgot about there being 2fans. I guess be better off ordering one Then. What's advantage of a 240 over 120? I'm using 8x8x6 plastic from home depot. I can't pics some reason. I've tried over and over. Never had a Problem posting pics on a forum before.
rgreen2002
Re: Wiring question
My fan was a 12v DC computer fan and I ran a separate wall wart power supply to it. I had a 220 V fan but could not fit it on the box :twisted: !
rgreen2002
Re: Wiring question
pointhunter75 wrote:Oh didn't know that. I guess was talking about power supply fan. Forgot about there being 2fans. I guess be better off ordering one Then. What's advantage of a 240 over 120? I'm using 8x8x6 plastic from home depot. I can't pics some reason. I've tried over and over. Never had a Problem posting pics on a forum before.
check here for posting photos: http://homedistiller.org/forum/viewtopi ... 52&t=15837
Snackson
Re: Wiring question
Post by Snackson »
Good size box for your stuff. If adding internal heatsink, it gets tight in a 6x6x4 so you'll have plenty of room. I've built them with both 120 and 240 fans depending on what the person wanted. With either you could hook it up to SSVR and make it variable speed with the controller.
pointhunter75
Re: Wiring question
My problem is it says too large even I shrink it well below max size.
pointhunter75
Re: Wiring question
Got ! Had get app. Look like a decent layout?
