Just Post a Pick of your Rig
Coors Knight
Re: Just Post a Pick of your Rig
Post by Coors Knight »
Received a Boswell 13.2Gal / 50L still for my birthday in August. Swapped the supplied stainless lines with 3/4" copper, added a 4 gallon "milk jug" thumper, and used an old stainless pot for a little bit larger condenser. Using city water for cooling so I used an old 6" inline fan and adapted the biggest(and nicest looking) motorcycle radiator off Amazon to help cool the water. My last run was multiple stripping runs and a spirit run- took all day and water didn't get above 80 degrees in the 50 gal rain barrel. (Outside temps at mid 70's). Regrets: my union's off the thumper- should have reversed one so I can easily eliminate the thumper if needed will address. Mods coming up next: bigger condenser with 1/2 instead of 3/8 line.... Let me know your thoughts and questions - the radiator mod was something I found a lot of people talking about but hadn't seen it done yet!! Any feedback good bad or otherwise I'll take!!!
Always under construction!!
MooseMan
Post by MooseMan »
Good mods CK.
Since you already have a big fan and you're running outside, you could try your hand at an air cooled condenser instead of the worm?
When stripping, you don't want the thumper inline, so yeah you need to change that fitting to suit but that's an easy fix.
higgins
Post by higgins »
I would definitely get rid of that silicone hose off of the parrot.
SW_Shiner
Post by SW_Shiner »
My 3 inch boka set up for a neutral run.
AusAsh
Post by AusAsh »
Only the water barrels stay outside. The rig is sanitised before each run and after its dried it's locked back up :lol:
jackfire57
Post by jackfire57 »
Jackfire
Stump Lake
Post by Stump Lake »
Rusty Ole Bucket
Post by Rusty Ole Bucket »
Stump Lake wrote: Mon Jan 06, 2025 10:55 am Image
I love the little mini jack for the jar stand! (Your rig is pretty killer too. :thumbup: )
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Stump Lake
Ah thanks. I found that on Amazon. Stainless
Steel Lab Jack Scissor Stand Platform (4" x 4") it was $13.54. I had been putting anything I could find to jack up my catch jars. Not a problem any more.
CO_Matt
Post by CO_Matt »
My little thing on stripping duty.
Copperhead road
Post by Copperhead road »
5 plate column bubbler
Copperhead road
Brandy still
Tex1320
Post by Tex1320 »
Here she is 10gal
VLAGAVULVIN
Post by VLAGAVULVIN »
Tex1320 wrote: Sat Feb 01, 2025 11:23 pm Here she is 10gal
One way run ticket? 8)
har druckit för mycket
PalCabral
Post by PalCabral »
My still this week when I did the water run and the vinegar run. Reflux mode and pot still mode.
Ongoing projects: Yellow Diamond Oated Bourbon v2; A Neutral spirit based on whiskey feints.
greggn
Post by greggn »
For safety sake, please remove the mason jar.
________________
Greig56
Post by Greig56 »
ImageMy design hasn't changed since I came up with a plan which fortunately has planned out nicely! It's been refined though! I've but now reneu'd and enlarged my Liebig (fm 18" to 24" and ~1" to 1 1/2" dia) And! my reservoir bucket!!! The Column is foam wrapped against winds. I have to stand on the stool to read my column thermometer!
This will run much cooler for longer which was my prev problem! No more!!
Retired fm a working profession. Thinking of making a decent mark on Man's Second Oldest Profession. Fanfare not required!
30Ltr Boiler Keg, Pot Still 3"x24" to a 1 1/2"x24" column made b4 found this site! New 24"x1-1/2Liebig
Captain Spaulding
Post by Captain Spaulding »
Digiboil, Alcoengine dome and head. Soon to buy the reflux column. Cooling water recirculated from a trash can other side of the railing. Why are all my pics rotated?
grumbles
Post by grumbles »
Here's what I'm working with. Well, mostly. This picture is old and I've rearranged a little bit, but that's the idea. It's an 8-gallon brew kettle modified to take two 1.5KW elements with 2" triclamp fittings. I liberated the lid's rim with an angle grinder and soldered on a stainless steel mixing bowl to act as a dome. Condenser is an 18" shotgun with 7 internal tubes, and baffles every couple of inches. I also have a shotgun reflux condenser and 3 bubble plates, but I don't run reflux very often.
Power control is an SCR with Auber controller built into a junction box with a cooling fan. Luckily, the house has two 20 amp circuits in the kitchen, one outlet on either side of the sink.
I'm happy with it overall.
Twisted Brick
Post by Twisted Brick »
Gorgeous shotgun, grumbles! A ton of knockdown power in a small package. Well done, sir.
grumbles
Post by grumbles »
Yeah thanks. I overbuilt it so it can stand up to most boiler and heating upgrades that I'm ever likely to do given the size of our property.
MooseMan
Post by MooseMan »
Nice job on the shotty grumbles.
I'm slowly collecting all the bits to make one almost the same but in 2.5" shell.
Can't wait to get started.
Bobbydigital84
show us your brewing rig
Post by Bobbydigital84 »
First build, also built a liebig, getting much better at soldering.
PalCabral
Post by PalCabral »
Test running my oldest still today, for the first time since 20-25 years. This is Natalia, a Portuguese Alambique, that my wife, then gf, gave to me for xmas, when she still thought this was a good and wholesome hobby. She doesnt anymore…
I used to make Brandy with it when I lived in Portugal, 10 liter of white wine from Minho, where the best grapes for Brandy, or Aguardente Vinica as it’s really called, are grown, only used to cost 5 Euros. I am trying to find the best power setting to get the optimal flow. The low wines come from yesterday’s sacrificial on the big still, Unni, and holds after dilution 32% abv. The first 0.5L collected in this run has an ABV of 74%, so I think I’ve found a sweet spot now.
I am planning to use Natalia when distilling infusions for Aquavit, Gin and other macerates I’ve made. I am also planning to do series of smaller 25L batches of Bourbons where I will using unusual grains as flavor component. I’ll do the stripping run in my big still and then do the spirit run in Natalia.
Rusty Ole Bucket
PalCabral wrote: Tue Jul 15, 2025 7:55 am IMG_6191.jpeg
VERY cool little setup!
Rusty
HeyBroChuckNorris
Post by HeyBroChuckNorris »
35L Digiboil with oakstills parts, including a few extra elbows which were attached for the vinegar and cleaning runs, but removed for the first real run. Helmet is for looks and a bit of copper, and included copper mesh inside of sight glass and off cuts in the boiler.
Bobbydigital84
Re: show us your brewing rig
Bobbydigital84 wrote: Thu Jun 26, 2025 10:39 am First build, also built a liebig, getting much better at soldering.
If anyone is interested here’s my upgrade. Hopefully i get the pictures right, i think i made it modular
MooseMan
Post by MooseMan »
Nice looking rig Bobby, that's a good long Liebig for stripping too.
Rusty Ole Bucket
Bobbydigital84 wrote: Tue Sep 02, 2025 9:30 am If anyone is interested here’s my upgrade. Hopefully i get the pictures right, i think i made it modular
Good looking set up Bobby. You're a fellow tripod user, I like it. :thumbup:
Rusty
Love the Liebig, good size and should have a heap.of knock down power.
