SS to Copper
1GUNRUNNER
SS to Copper
Post by 1GUNRUNNER »
Here I start in a series of seriously newbie questions:
Planning on a 15 gal SS keg.
How come I see copper coming out of the top of all of the SS kegs? Wouldn't continuing with SS be better?
rednose
Re: SS to Copper
Post by rednose »
I'm afraid that not many folks here will answer those questions which are that basic.
You missed to make your homework buddy.
olddog
Re: SS to Copper
Post by olddog »
1GUNRUNNER wrote:How come I see copper coming out of the top of all of the SS kegs? Wouldn't continuing with SS be better?
Its easier to build with copper, you just need a simple propane torch, whereas SS needs a TIG welder.
Also you need some copper in the system to remove the sulphides in your distilate.
OD
1GUNRUNNER
Re: SS to Copper
I am a certified welder with a welding shop and a TIG torch so that is not a problem.
With the 2" Sankey outlet what is the idea of stepping it up beyond that to 3,4,6" ?
olddog
Re: SS to Copper
Post by olddog »
The bigger diameter column, the more heat is required to produce sufficient vapour flow, bearing in mind what type of still you are building etc.
OD
squidd
Re: SS to Copper
Post by squidd »
1GUNRUNNER wrote:Here I start in a series of seriously newbie questions:
Not quite all.
There are some beautiful SS keg/column combinations.
Have a looksee at Hookline's.
The required copper path can be in the packing, and/or the condenser(s).
squidd
