I have been doing ALOT of reading off this site and is by far the best info source.
I will asking Question, in what I hope is the relevant section, as its quite long winded and probably not the best place to ask now.
I'm only just getting into the brewing and tried a batch not too long ago.
I'm going for a the neutral spirits and then adding the flavours, I think its a good way to start and learn before getting adventurous with flavoured washes
I have inherited a Distilled water still (2L boiler straight into a condenser, no column), the boiler has 2 separate heat elements (power?) which at the moment are either ON or OFF some there is plenty of power as it boils the solution in about 5 minutes…YES I know its too small but I figure I would learn the basics on a this small POT still unit before getting a larger REAL still.
My question is here,....regarding "Possiblity of setting up a continous flow small pot / colunm still"
LINK to follow
Cheers
