RTD's and thermocouples
If it plugs in, post it here.
Manback
Post by Manback »
So, I've been ringing around and googling everywhere (unfortunately nowhere convenient to go in ChCh)
I want a temp sensor to go to a digital screen for my still. Can anyone tell me - what is the minimum probe length that would be physically ffeasible for each of these two types of sensors?
As in - it's going into 1" tube, so the shorter the better.. obviously, we can add a little extension, but we'd rather not..
Anyone got info?
Cheers guys
rednose
Re: RTD's and thermocouples
Post by rednose »
If you want to control a switch or heat source you would need a thermocouple controller, if you only want to read the temp you can go for a K-type instrument.
The shortes probe in K-type I have bought is this (2 cm):
http://cgi.ebay.com/1-K-type-Thermocoup ... 1e5b3cff3c" onclick="window.open(this.href);return false;" rel="nofollow
There exist a very cheap one but the probe is losen in a srew and doesn't seal, you would need to soft solder it to seal (won't buy that one).
joe
jdpete
Post by jdpete »
You could try auberins.com
Jeff
hoody
Re: RTDs and thermocouples
Post by hoody »
Quite a few on Trade-me. I've got a cheap one in the post at the moment. Dont think it is exactly what I am after but for $8 I cant go to wrong. There is a few probe type one's on there varying from $10- $120.
I tried Dick Smiths on the weekend too but they just looked at me funny (that shop sure aint what it used to be!)
Hoody
hoody
Post by hoody »
Hoody
olddog
Post by olddog »
hoody wrote:I tried Dick Smiths on the weekend too but they just looked at me funny (that shop sure aint what it used to be!)
I managed a couple of their stores when Dick owned them, now their owned by Woolworths that's when they went downhill. :evil:
OD
olddog
Post by olddog »
Try Jaycar NZ, they have got thermocouple's
OD
Manback
Post by Manback »
Ended up having to go through InTech to get one with the fixed thread fitting etc.. man, display units aren't cheap!
Shortest probe possible was 10xDiameter, so 30mm with a 3mm diameter probe.. perfect!
Samohon
Post by Samohon »
I got 2 K-type probes when I bought my thermometer, but I could'nt tell what the probe material was made from...
Bought a new SS 30mm K-type probe from RS Components for £8.00 ($11US)...
I then hard soldered it into a 10mm x 40mm peice of copper pipe that slots inside a peice of 12.5mm copper with a wrap or 2 of ptfe...
Worked out ok...
Us here are HD are a very inventive lot... In most cases, there's a way round the problem... :D
♦♦ Samohon ♦♦
Caprimulgus
Post by Caprimulgus »
Wondering what you plug those thing into? What are those display units called? Any pic or URL?
Nobody puts baby in the corner....
http://homedistiller.org/forum/viewtopic.php?t=18918
Manback
Post by Manback »
There are milllions of options when it comes to the process indicator - depending on what you want - number of inputs, size, alarm etc..
I'm going to InTech in about 30 mins. I'll let ya know. The thermocouple has a 1/4" BSP fixed thread btw
