RUBBER GROMMETS
RUBBER GROMMETS
CAN A SMALL RUBBER GROMMET BE USED IN TOP OF MY COLLUM TO HOLD MY THERMOMETER? I THOGHT ANY RUBBER IS BAD?
Re: RUBBER GROMMETS
THERE IS A "CAP LOCK" KEY ON THE LEFT SIDE OF YOUR COMPUTER. We all wish you would use it.
many folks simply wrap the therm with PTFE tape till it fits snugly in the therm outlet. Others use a piece of wood with a hole in the center for the therm probe and tapered on the outside to slide down into the outlet.
