The copper packing i used in my column (stainless steal) oxidized dark black along with some copper tubing i removed the mesh and scrubbed the column there is a bit of residue left over. My question was is if i can just scrub everything clean and continue on as normal or should i ditch the copper tubing i used and start anew?
thanks
black copper oxidization?
- Location: you can find me in the ring, behind the bar, or in water usually
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
Re: black copper oxidization?
soak in vinegar or vinegar/salt.rinse well after.
+1 Dnder
Safety is always #1. Without it you wouldn't be around to enjoy the hobby.
No matter how much of an expert you are, there is always someone better. Listen to their words.
Listen. Understand. Repeat.
You can soak it in vinegar as dunder suggests and it will make it shiny again, however the oxidation of the copper is not a bad thing. If it were me I would just rinse it with some hot water. My still is all copper and the only cleaning it ever gets is a sponge wipe down and rinse w/hot water. Just think about your spirit run, it starts out with your heads containing methanol and acetone which are great for cleaning and sterlizing.
Big R
Big R
