copper packing
copper packing
I run a mildly packed column with copper. Wash it off with water hose after each run. My question is how often do you replace the old packing with new?
Re: copper packing
it will start to fall apart.
Re: copper packing
Ok, thanks. Just wasn't sure if there was a max number of runs you should use it for.
Re: copper packing
copper is sacrificial.over time the acids "eat" away at it.this makes copper sulphate witch drop to the bottom of boiler.this is good as it removes sulphur compounds from distillate.
