Is copper glue safe?
someone i know has used copper glue for his still for many years now i haven't got soldering equipment... is the glue a complete nono
or can it be used?
Re: Is copper glue safe?
you should have a read of the MDS for the product
if it has more than tin and silver in it IMO it's not safe
but at a guess as silver and tin are not a "liquid" at room temp then it's got other stuff in it if it's like putty / glue
i reckon it's unsafe
maybe ask around a few mates and find some soldering gear
you could use one of these old school soldering irons i reckon if your preheat you parts a little
i have one i use form time to time for stuff and heat it with a burner
- Expat
Definitely NOT something you want to be using.
Likely its a cyanoacrylate based glue
"Toxicity
The fumes from CA are a vaporized form of the cyanoacrylate monomer that irritate sensitive membranes in the eyes, nose, and throat."
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Yup... I'd deem it unsafe. You can get a small torch and solder for pretty cheap. It's real easy to do with a bit of practice. Watch som vids on how to do it properly and read some threads around here (there are a couple good ones) and you'll pick it up it no time. Tell your friend to quit making poison with his still.
Here is a web site with the available copper bonds and their safety specification sheets.
http://www.cyberbond1.com/adhesive-solu ... sives.aspx" onclick="window.open(this.href);return false;" rel="nofollow
massive nnono then ill just buy a soldering iron then
youll get more use out of a cheap tourch and a bottle of latern gas than a soldering iron unless you do alot of electric connections. for around $10 youll have the tools you need to solder.
+2, get yourself a cheap torch and some lead free solder...
Be safe man...
Be safe man...
♦♦ Samohon ♦♦
+3 no no no, learn to use a torch, and lead free solder, ones health is not worth it, alcohol is bad enough with out xtra heavy metals and added chemicals in it!
It is what you make it
