Fermentation/Mashing Process
striker85
Location: North of the Elms, West of the Brass, East of the Silk and South of Basketball
Post by striker85 »
I think I have the gist of these processes, but I seem to be inept at formulating a proper search to find information that I can understand.
Yeast + Sugar = Booze (VERY generally)
So, the two types of washes can be sugar based or grain based (sugar referring to added refined sugar).
For an all grain wash, the grain must be malted and then mashed. For mashing, the malted grain is to be heated for a length of time (not boiled) to allow the enzymes created during malting to convert the starches to sugar. Once the grain has been mashed, in order to produce the fermentable sugar, it is rinsed (sparged) to get every last bit of goodness out. Then add yeast and...the rest is history.
Now, the concept here is that the grain is the sugar, yes, but it also is the nutrients for the yeast.
So, in a sugar wash, there needs to be some sort of nutrient because sugar water and yeast won't work; the yeast will die without food nutrient. That is why stuff like tomato paste is added. From there, the process is the same as all grain. Add yeast and go.
So my confusion starts when considering the sweet feed recipes here. By that logic, they are in essence just a sugar wash that uses the feed as a nutrient base. Because my feed has pellets, I want to cut back on how much I use in order to avoid too much garbage accumulating in the fermenter. So the question is, how much nutrient base does yeast need? Is there a ratio to follow, or calculation? Do I have a correct grasp on the processes?
Also, the lees...when the wash is done and the lees are left, do you just discard the feed and keep the fine sludge (which I assume is yeast)? With that you can start a new batch without adding more new yeast?
This topic has 5 more replies
Register Login
