Ok i did my first run of oat whiskey (from the recipe on the site (tried and true) everything went good and i just tested with a proof and tralles hydrometer here are my results, i ended up with 5 of the medium mason jars (maybe a pinte i am not to sure) i threw out the first 500 ml.
Jar #1. 80 PR and 40 TR
Jar #2. 104 PR and 52 TR
Jar #3. 104 PR and 52 TR
Jar #4. 94 PR and 47 TR
Jar #5. 70 PR and 35 TR
all of the above was tested at 60 degrees
now when i started i did not have the tralles hydrometer so i read an artical here in the forum that said if it burns in a spoon then its over 100 proof and if it burns on a plate then it is below 100 but more than 75 if this is correct then something dosent seem right because all of my jars burnt in a spoon i was collecting jar #6 when i got a different feel and smell so i was thinking that tails were starting so i collected another 2 jars as tails and shut it down. the whiskey taste great i am very pleased of the out come just not sure if i am reading everything properly, i am assuming that 80 PR on my hydrometer means 80 proof and the tralles is the amount of alcohol (40%) or is there a calculation that i have to do???
ok i checked the hydrameter with some store bought whiskey 40% alcohol and the hydrometer read about 68 proof and 28% alcohol could it be off that much?????
I've heard of some being off. 6% or 12 proof is a lot. The paper scale inside the hydrometer mite have slipped some? Who knows. If it were me I would check it against another store bought. And adjust my readings from there. Or get another one? They are cheap and its good to have a spare.
Thanks for the reply, it is exactly 10 proof off and 5 % I checked it on another store baught and another hydrometer, maybe the paper slipped inside who know's anyways aslong as i know i am good with that but i will pick up a new one in time.
