Glass Barrel
wannaB1
Glass Barrel
Post by wannaB1 »
Picked up a glass barrel this past weekend, though it would be neat to oak in. If I can get oak in it. I'm going to read up on drilling glass so I can make the top hole large enough to put my oak in it.
NY Chris
Re: Glass Barrel
Post by NY Chris »
Wow that's a nice container, what was in it and what was it marketed for?
ozone39
Re: Glass Barrel
Post by ozone39 »
use a small diamond tip rotary bit on a dremel tool (1/16"), start by drilling a hole then work your way around. need to run water over the glass while your cutting it. I had to cut some pyrex, that's is how i did it. might be able to use a diamond tipped hole saw at a slow speed, water is absolutely necessary though no matter how you do it...
BourbonStreet
Re: Glass Barrel
Post by BourbonStreet »
NY Chris wrote:Wow that's a nice container, what was in it and what was it marketed for?
Looks like Early Times, a "low-end" Kentucky bourbon.
Boda Getta
Re: Glass Barrel
Post by Boda Getta »
Nice score! I think I would just split the oak small enough to go into the top, then char. If the barrel proof will be the recommended 125-135 proof, I may be a little concerned with that plastic spigot.
Good luck
BG
NY Chris
Re: Glass Barrel
Post by NY Chris »
Might have to buy some just to get the bottle, use the bourbon for my next cleaning run. lol :D
Probably not that bad, I'm just more of a scotch drinker.
Good luck with the project.
wannaB1
Re: Glass Barrel
Post by wannaB1 »
I was also worried about the spigot at oaking proof.... Last thing I want to do is break it so for now I will read up on drilling glass and practice on other bottles. Wonder if I could find wooden spigot to fit it, hmmm
Re: Glass Barrel
Drill your larger hole as described above then buy a cork to match from a place like this to stop it.
http://www.widgetco.com/large-cork-stoppers-standard" onclick="window.open(this.href);return false;" rel="nofollow
mash rookie
Re: Glass Barrel
Post by mash rookie »
I drill and cut glass all the time. Yes, you must use a diamond tip bit with plenty of water. Go slow. Heat is your enemy. Personally, I would not risk it.
I would use JD chips that would fit through the existing hole and enjoy it!
Tater
Re: Glass Barrel
Post by Tater »
Thats a nice jar. Id keep it as is and use to serve after aging with my own label on it and a nice wooden made cradle .
Prairiepiss
Re: Glass Barrel
Post by Prairiepiss »
Mr would be better suited to comment on this. But I would be afraid a wood spigot would swell and put to much pressure on the glass? I would hate to see that beautiful glass barrel crack on you.
Posted while Tater did. I like his idea. :thumbup:
DFitz
Re: Glass Barrel
Post by DFitz »
Personally I wouldn't alter the glass keg. I usually find white oak dunnage in good shape, cut it to 3 or 4" lengths and then split it with a hatchet to 1/2 splinters. I toast these at 350-375 degrees for an hour or so to get a good medium toast then char them on a burner or with a torch to get a good char. This way I can fish them out and continue aging (or flavoring for a better word). I typically let JD chips do most of the work in cleaning things up when I use this method. It seems to work well.
augiecrazy8
Re: Glass Barrel
Post by augiecrazy8 »
If anyone is interested you can do a search on ebay for "early times barrel" and there are several empty barrels. Around $20 total with shipping.
thecroweater
Re: Glass Barrel
Post by thecroweater »
on account of the plastic tap and the risk of busting it why not just age ya likker in a jar, wooden barrel, demijohns ect and transfer it to the glass display barrel at drinking proof would look the gear all coloured up in that :thumbup:
