Non kink hose
rgarry
Non kink hose
Post by rgarry »
I'm having a hard time finding a non kink 6ft hose. Has anyone had any luck. I'm trying to avoid buying a larger one and cutting it thinking it will leak less if from manufactor.
bellybuster
Re: Non kink hose
Post by bellybuster »
What are you using it for?
rgarry
Re: Non kink hose
Post by rgarry »
I use it as the outflow for drain from flute. All the cheap ones kink, in part because the water is warm. I have a good hose going into flute, then there are 2 drain that I connect into one good hose.
bellybuster
Re: Non kink hose
I use the cheap reinforced vinyl hose at any hardware store. The stuff with the weaving in it.
rgarry
Re: Non kink hose
Post by rgarry »
I can't find any in the 6 ft range. Might have to just make one.
NineInchNails
Re: Non kink hose
Post by NineInchNails »
Could try PEX. It's tough stuff. A bit on the stiff side but once it warms up it softens up and once cool it holds its shape.
Prairiepiss
Re: Non kink hose
Post by Prairiepiss »
Lowes home depot and ace all sell the stuff by the foot.
I use stuff like pex. And I want to switch over to all pex. Using red for hot blue for cooling water and white for fresh supply water.
rgarry
Re: Non kink hose
Post by rgarry »
Thanks, will check it out.
