bypass thermostat on my hot plate
If it plugs in, post it here.
rehrlich
Post by rehrlich »
Hi, ive been reading about using a router speed controller on my hot plate. Ive been trying to find a thread on here for bypassing the thermostat. Any help would be appreciated :crazy:
Od1tspyd3r
Re: bypass thermostat on my hot plate
Post by Od1tspyd3r »
Depending on the model, u might be able to just move the temp probe, mine was riveted to the bottom of the surface inside the unit. Drilled e, out and moved it towards the inner front and no more cycling. There is a thread some were about it.
rehrlich
Post by rehrlich »
No idea what that means. When I took mine apart I saw a few wires and everything else was inside the knob
Od1tspyd3r
What is the model number or post a pic of the inside.? Btw what type is it cast top coil top or induction.
rehrlich
Post by rehrlich »
When I try to upload a pictirr it says picture is too big
rehrlich
Post by rehrlich »
I'll explain it the best I can unless someone can tell me how to upload pictures. It has 2 wires on it that go from the temperature control knob to a little metal board that the burner coil comes off of. On the temperature control know where the wires are theres a little white circle thing that the wires are connected to. One on top and one on the bottom (wires). The burner I have is a little cheap rote aid burner. The brand is living solutions ands its 1100 watts
Prairiepiss
Post by Prairiepiss »
You have to resize it down. With the widest side of the pic being 600 pixel. Should be able to do this with any photo editor. Or even paint.
rehrlich
Post by rehrlich »
Heres the pictures of the inside
rehrlich
Post by rehrlich »
And another one
Prairiepiss
Basically to bypass the switch. You will have two wires from the element. And two wires coming in from the plugin. You need to connect one of the wires from the plugin to one of the wires to the element. Then connect the other two wires together. One of those connections are probably already made for you. And the only one you would need to worry about is the one that runs through the switch. And insulated the two different connections. So they can't arc or ground out. . Or shock you. There may be a third wire coming from the plug. It would be green and is a ground. It should be grounded to the metal case. As a further safety precaution.
Caution
This mod will make it so that the element will be on full blast. Any time the unit is plugged in. So it would be recommended that you plug it into a controller that has a way to shut it off.
rehrlich
Post by rehrlich »
Trying to understand. Still a little confused
Prairiepiss
Just hook the element straight up to the cord that plugs into the wall.
rehrlich
Post by rehrlich »
The cord the plugs into the wall is split into two. One going to the element and one going to the temperature switch
rehrlich
Post by rehrlich »
Im gonna buy a better burner. This one is cheaply made
Prairiepiss
Yes and one coming from the switch to the element. Connect the two wires that connect to the switch together. Taking the switch out of the system.
John Barleycorn
Post by John Barleycorn »
A picture speaks a thousand words ... read Mr. P's instructions while you look at the pic ... something like this:
Connecting the extra wire (blue) isn't necessary ... but it keep it out of the way ... and available if you want to restore the plate to normal operation.
Prairiepiss
Good pic. :thumbup:
Glad you posted it. I was about to draw one out and post it. That could have been ugly. :roll:
rehrlich
Post by rehrlich »
Got it! Very nice diagram thank you! What happens to the wire going from the element to the controller? Looks like they wrapped it around something
rehrlich
Post by rehrlich »
Wow I finally got it and its working! Thank you guys for the help. One last thing im gonna buyns router speed control for temperature. Other than that how safe is it bypass the thermostat like that? Just dont want to catch it on fire. The outside shell of it is plastic. And yes I always keep a fire extinguisher handy
Od1tspyd3r
Make sure it has a space under it to let some of the heat escape, keep a hand on the temp of your pot . Maybe throw a simple switch in the line for a kill switch.
Od1tspyd3r
Waring 1300 , been using it this way for a while. One internal pic of the thermocoupal just removed from its spot, drill up couple of rivets and remove the aluminum bracket. 2nd internal pic new position of thermocoupal. It doesn't cycle any more.
rehrlich
Post by rehrlich »
Both those pictures look identical. You just bypassed the thermostat right?
Od1tspyd3r
Here's a better one. It's the thermocoupling just after being removed.
simpletime05
Post by simpletime05 »
Od1tspyd3r wrote:Here's a better one. It's the thermocoupling just after being removed.
do you have any control over the temperature now or is it on full temp when plugged in?
rehrlich
Post by rehrlich »
I haven't used it yet. I bought a voltage regulator and im gonna test it out soon
Od1tspyd3r
with were i have the thermocoupling placed its on full, i do have on off control at the knob, havent really played with moving the coupling to get more control out of it , but it works well. think i got lucky with the size of the still and the hotplate
CrazyPapa
Post by CrazyPapa »
I also use a waring 1300 watt, I purchased a router speed control at harbor freight for under $20.00 . I did no modifications , I just plug hot plate into control and adjust power as needed. It will really find tune to what ever temp I need.
Od1tspyd3r
Do you have any problems with it cycling and or what size pot r u running
CrazyPapa
Post by CrazyPapa »
I have a 6gallon pot, the thermostat is set the whole way up. I run it on full till it comes to temp and then I switch it to variable , can control temp very precise. The unit does not cycle
Od1tspyd3r
Im looking to move to that size myself. How long is your heat up time witht that
