High Temp Yeast
Coyote Piss
High Temp Yeast
Post by Coyote Piss »
I tried to search this question but I keep getting an error that the words are to common to search.
My question is, where I live the temps in the summer can easily climb well over 100F and I do not have air conditioning so my mash will be fermenting in these temps. Is there any yeast that will tolerate temps that high or am I going to be restricted to running only when our temps are below 95?
Survivalists are NOT Preppers and Preppers are NOT Survivalists. A Survivalist knows how to SURVIVE and THRIVE without PREPS and a Prepper DIES without them. Which are you?
MadMasher
Re: High Temp Yeast
Post by MadMasher »
Most yeasts will survive at 100F, proofing temp is 105 on most i believe. They'll work faster too. Problem is that they will be stressed and create undesirable compounds, making less good stuff from the sugar. If you have a basement or somewhere cooler to ferment that would be better. Some reading that will help https://www.google.com/search?rls=en-us ... &rls=en-us
People talk about my drinking but never about my thirst.
Re: High Temp Yeast
If you have access to running water a wort chiller might be used lower the daytime fermenter temps.
1118 can survive at 100' it is also know for producing the least amount of off flavors at any temp.
Prairiepiss
Re: High Temp Yeast
Post by Prairiepiss »
I would be looking at a way to chill or cool the fermenters. Instead of trying to ferment so high.
Something as simple as it sitting in a tub of water. With towels draped over the fermenter into the water. And a fan blowing on it. Placed in a shaded cooler area.
And DADY distillers active dry yeast. Likes higher temps. But still not quite that high.
Coyote Piss
Re: High Temp Yeast
Thanks for the info. I guess I will try and use a washtub full of water and throw in some froze water bottles to keep it cool through the day. No basements here or running water. I have seen temps in the house climb to 110 in the daytime. Luckily not all the time, but enough days to put a hurt on yeast.
Jimbo
Re: High Temp Yeast
Post by Jimbo »
Coyote Piss, are you the illegitimate offspring of a couple of our brethren??
Bakers and Distillers yeast tolerates higher temps, 80's. Dont even think of using a beer yeast or wine yeast at them temps. recommendations below are good. If you dont have a spot that stays cooler in your house you might consider digging a tiny little 'celler' couple feet deep, on the north side of your house where the sun doesnt hit (or south side I guess if youre in Oz). Throw a 4x4 sheet of some heavy plywood over it. Earth should keep it much much cooler.
