potentiometer question
If it plugs in, post it here.
apdb
Location: big ole'island on the West Coast Canada, soon to be underwater when the big one hits
Post by apdb »
My SSVR calls for 470-560kohm @ 2w
I understand that I look for the larger value when choosing the pot.
560k seems to be rarely used and a little hard to find. I was given a honeywell 500k for free. This means i won't reach the full on setting. Correct?
On a 5500w 240v is that a concern or will that missing 60k make a major difference.
Is there a different inexpensive solution?
I do know that im not concerned about low or off. I'll just unplug to get there.
Aaron
Re: potentiometer question
A 500k ohm Honeywell pot will work fine.
Pot's and resisters have a tolerance rating. In other words it may be +/- a percentage of what the stated value is.
So a 500k 10% tolerance resister may be anything from 450k to 550k.
If the max resistance is too low your controller may not go all the way to zero watts.
Also the input of the ssvr has the same tolarances. Put it together and give it a try.
sambedded
Post by sambedded »
SSVR gives a full power to a load when.pot resistance is zero. So you can get max using absolutely any pot. And SSVR shuts power when resistance is around 400K.
sambedded wrote:SSVR gives a full power to a load when.pot resistance is zero. So you can get max using absolutely any pot. And SSVR shuts power when resistance is around 400K.
Just took the cover off the controller and checked the pot with my fluke 77.
Sambedded you are right. I got it bassackwards.
