My current plan for my new 50l boiler is a simple plug in controller to a 2000w element, potentially upgradable to 3000w. Plugged into a normal service output (20 amp breaker).
I have 25amp rated wire for future proofing on my 240v mains.
But then I look at an unused oven connector point, basically three bare wires for wiring into a stove sticking out of the wall.
Its an eyesore basically, and unused but it has a 50amp breaker unused by any other appliance and gives me room to expand my elements power...
I have a couple of options, get a power point installed (or do so myself) so the controller can simply be plugged in there, or to wire the controller in directly?
I'm not an electrician but I trust myself working with 240v and to do a safe job, but would like the voice of experience and maybe an electrician to help out!
Of course safety is a priority, especially in an apartment.
While I'm asking questions, what is the thread size for your elements? I've read about 1" threads that are actually 1 1/4".
I have in front of me the locally available element with a matching coupling labeled 1 1/4" but exactly zero of its dimensions fit that dimension.
Its internal diameter is 1.55", is this a larger thread than the Camco elements you all use?
In other words if I order a nice low density element will it fit?
Controller wiring
Re: Controller wiring
Would a strip connecter be suitable? I can get one rated to 30A and would provide a protective housing.
A random example - http://www.theelectricalwarehouse.com/p ... 38c411dcba" onclick="window.open(this.href);return false;" rel="nofollow
- kaziel
I'm using 1.25" element. I would install wall socket for connection but it can be done with connector that you posted.
Vodka consumed wisely is harmless even in large amounts.
My all stainless 2" VM still
My all stainless 2" pot still with Dimroth condenser SS Pot Still
My malt mill - two roller - DIY
My keggle - mash/filter tun
I would install a receptacle so you can plug your system into. That way you can remove for cleaning
There are different thread sizes on water heater elements.
1 inch is the most common for HD use.
Simple pot still for simple likker
Moonshine and oysters, the breakfast of champions
"Don't turn on the lights cause I don't wanna see. Mama told me not to come" Randy Newman
- superdaveva
Do not use your existing 50 amp stove outlet.if your running 110 v 20 amp you need a 20 amp single pole circuit #12 copper wire. If you hook up a single pole circuit to a double pole breaker it may not trip in an emergency.
just deal with it bitches
Thanks for the advice guys, superdaveva, I have single phase 240v ( I think that's the term!).
I think Ill go with the standard 16a wall plug for now and look towards a larger element and a heavier amp plug and point in the future if I cant stand the heat up time.
- superdaveva
