lets talk mashing thermometers
WooTeck
Post by WooTeck »
ive decided that im going to invest in an electric thermometer with an alarm. it will be used in the boil pot and fermenter its self.
mainly because I often start heating water and when I check it its over the desired temps. ill also be able to keep the mash within the needed temps.
anyone have any suggestions on brands or particular pieces of kit?
have done a little web browsing and some ether aren't suitable for liquids or have short probe cables. :crazy:
eck
Sungy
Re: lets talk mashing thermometers
Post by Sungy »
I use a Johnson controls a419. There about $60 on eBay. You can make a well for them out of 3/8 copper tube and a compression fitting. I have one for my fermentor that controls a fish tank heater. The heater is inside a piece of 2 inch copper pipe (pipe has water in it) that I mounted to the fermentor lid and hangs inside my fermentor too 4 inches above the bottom of the tank. The sensor is in a well made from 3/8 copper pipe located near the bottom of the fermentor. I have also used one in my power controller to monitor 4 temperature sensors. I used a 2 pole 4 position switch. This allows for switching the sensor input.
heartcut
Post by heartcut »
One way to go would be a single loop controller that will give you alarms and a control output if you need it. The Omega CN730 series is a good one, inexpensive and Omega gives good after purchase support. The one with a pulsed DC output will switch a SSR, avoid the relay output for heat control because they wear out. You can buy PT100 elements in lots of configurations, I'd suggest them over TC because of price and accuracy.
http://www.omega.com/pptst/CN730_Series.html" onclick="window.open(this.href);return false;" rel="nofollow
heartcut
W. H. Auden
Tater
Post by Tater »
If you can run finger through it 3 time but not 4 its ready for the malt. :mrgreen:
heartcut
Post by heartcut »
Used to use the 3 & 4 finger test for...
never mind.
heartcut
W. H. Auden
