3 ton AC coil
frodo
Location: hiding behind a pine tree. bout 100 miles east of new orleans
3 ton AC coil
Post by frodo »
I have a 3 ton A coil from a split system heating/cooling unit.
I am sitting here looking at this thing,,,i can scrap it for the copper.or
any suggestions on using it to condense a still?
Re: 3 ton AC coil
You could use it to cool your recirculating water in a closed loop system. I certainly wouldn't attempt to run alcohol vapors through it.
just sayin
Re: 3 ton AC coil
Post by just sayin »
+x, SS!
Hound Dog
Re: 3 ton AC coil
Post by Hound Dog »
still_stirrin wrote:You could use it to cool your recirculating water in a closed loop system. I certainly wouldn't attempt to run alcohol vapors through it.
++. I have a small cooling coil from a walk in fridge that I have hooked to my cooling rez. That baby would definitely do the job if you have the room. Don't have to worry about changing water with that.
Using Google Search
