Easy way to bend soft copper without a kink and a bender
cbrophy
Post by cbrophy »
The best way to bend soft copper without a bender. First thing to do is bend the copper tube straight. Then cap or crimp one of the ends. Fill with fine sand, cap or crimp the other end and bend. Its real hard bending the copper but you will never have kink.
Its a old electrican trick when bending condeut
dr_gribb
Post by dr_gribb »
I used salt insted of sand. Worked like a charm. (found the tip on a thread i cant find now)
The best thing about the salt is that you can easely wash it out by connecting one end of the pipe to a water hose.
mikeac
Post by mikeac »
I have yet to try it, but i heard people used water too. seems like it'd be easier to fill and rinse out...
iamkwood
Re: Easy way to bend soft copper without a kink and a bender
Post by iamkwood »
cbrophy wrote:The best way to bend soft copper without a bender. First thing to do is bend the copper tube straight. Then cap or crimp one of the ends. Fill with fine sand, cap or crimp the other end and bend. Its real hard bending the copper but you will never have kink.
an old shiner told me this when i was younger 12 or 13 or so. and wrapping it around a round post or tree.
byacey
Post by byacey »
If you bend it around a tree, doesn't this necessitate cutting down the tree to remove the coil? :?
I'd sooner have a bottle in front of me than a frontal labotomy.
Husker
Post by Husker »
The "old" shiner had already probably cut down the tree to cook the wash :)
H.
Old_Blue
Post by Old_Blue »
That's what you fire the boiler with.
Fire is the devil’s only friend - Don McLean
Jump in where you can and hang on - Brisco Darling
CoopsOz
Post by CoopsOz »
With green wood?
Old_Blue
Post by Old_Blue »
Not green - way too much smoke.
I was talking about using a tree that was marked to be cut anyway and add it to the pile for future use. Sorry I wasn't more clear.
goose eye
Post by goose eye »
how yall seein all that smoke in the dark
you set up under a hollyberry or such. smoke goin up is broke up. fat lighter will catch up most anythang. most all use to keep warm an cook by wood. now some make white smoke an some make black . look about you youll find what you need. some toted stove wood to get it goin to.
mostly you only worryed bout worm.
so im tole
Dnderhead
Post by Dnderhead »
Goos is right furthermore you did not have a big blazing fire you wanted
coals sortof feed fire from outside in like a coal forge .biggest problem
around hear was dear hunters ,they tend to show up at the wrong place
wrong time even if they do not belong there
