Interesting paper on Unmalted barley and enzymes.
Fart Vader
Post by Fart Vader »
Very technical paper, but overall I think an interesting read while waiting for the boiler to come up to temperature.
From what I understood, 100% unmalted barley can be done successfully using enzymes.
It also appears that a ratio of 60% unmalted to 40% malted is the optimum ratio without enzymes.
I picked up a 55lb sack of unmalted barley this weekend for $11.
I'll be giving it a try with the enzymes soon.
32005mashing_unmalted_109.pdf
(518.08 KiB) Downloaded 146 times
My double walled boiler build: The Mashimizer. viewtopic.php?f=50&t=64980
MichiganCornhusker
Re: Interesting paper on Unmalted barley and enzymes.
Post by MichiganCornhusker »
Interesting paper.
I haven't read through it all, but looking at one of the graphs, it seems to show a great increase in filterability with the addition of as little as 15% malted barley to raw barley.
I've done a straight unmalted barley mash before, and it was one slimey mess for sure. Maybe by just adding a small amount of malt that could be avoided.
Thanks for posting, looking forward to taking a little more time to read through it more closely.
moosemilk
Post by moosemilk »
Tried a bunch of grains unmalted. Sure you can do them, but the only one that comes out of the still worth drinking (so far) is corn. Anything else seems to need a bit of malt for the flavor. The 100% unmalted barley I did I ended up tossing the low wines back in with a run from a corn and heavy rye malt. Unmalted seems to be lacking something.
Fart Vader
moosemilk wrote:Tried a bunch of grains unmalted. Sure you can do them, but the only one that comes out of the still worth drinking (so far) is corn. Anything else seems to need a bit of malt for the flavor. The 100% unmalted barley I did I ended up tossing the low wines back in with a run from a corn and heavy rye malt. Unmalted seems to be lacking something.
That's the part that I've been wondering about, flavor.
Did you use enzymes?
moosemilk
Post by moosemilk »
Yes, with enzymes. I started a thread using enzymes to reduce the amount of malt needed. Haven't had much time for experiments, but thinking of reviving.
http://ww.homedistiller.org/forum/viewt ... 11&t=53796" onclick="window.open(this.href);return false;" rel="nofollow
bentstick
Post by bentstick »
I use enzymes for conversion and malted grains for taste and added Xtra conversion or vice versa,in short use both now!
It is what you make it
moosemilk
Post by moosemilk »
bentstick wrote:I use enzymes for conversion and malted grains for taste and added Xtra conversion or vice versa,in short use both now!
+1 likewise. Still get flavor from malts, but don't have to use as much
Fart Vader
Cool, you guys are saving me some experimentation time. What ratios have worked for you?
Something like 10% malt for flavor plus 90% unmalted?
Inquiring minds want to know.
P.S. just been reading up on your thread moose, I read it a few months back but got lost in in all the reading I've been doing. Typical newbie. Oh look something shiny, let's go there. Oh a butterfly, let's follow the butterfly... I think you you know where I'm going with this.
thecroweater
Post by thecroweater »
If you only use enzymes it will be insiped as, great for neutral but dissapointing as a whiskey, how much to use depends on how much malt flavour ya want. I would say not less than 10% for a very light whiskey and 20% or more for normal average whiskey profile
moosemilk
Post by moosemilk »
I usually do the booner's recipe for corn, but sometimes like to add a little malt to change the flavor. Malts for me are very expensive (I have had some success with malting barley from the feed store though). So I resort to enzymes. I'm using anywhere from 5-10% of my grain bill as malts, substituting for corn in the booners. I like the flavor. The corn tends to lose some flavor but leave behind a sweetness, and using rye or barley malt, even in just small amounts, keeps a little flavor in there. It's about preference and what you like. Also the use of enzymes allows me to cook the malts with my corn, and I haven't had an infection yet (A mild lacto once, but i think that was from checking on the gravity with a thief i hadn't sanitized).
HDNB
Post by HDNB »
i took moose's experiment and ran with it, using cob unmalted and 2 row malt barley in the following proportion of total grain bill.
imho:
0% thin, lacking.
5% makes a noticable taste difference over no malt.
10% is nice light whiskey
15% hits a real sweet spot for me
20% is full bodied
25% is no noticable difference over using malt for full conversion (say 40% without doing math) so...saving 15% malt on the overall grain bill.
i used the same heat protocol and same doses of seb ht and seb gl for all batches regardless of malt%
now i drink for evil.
moosemilk
Post by moosemilk »
HDNB makes a damn good COB i'd like to add.
Still have a few ounces left, and it just gets better every day! BTW HDNB, it has developed a very nice caramel nose to it now and holds it in flavor as well, along with fantastic grainy notes. That one is a winner for sure!
Fart Vader
Great feedbck. I'm going to fire up my new steam wand this weekend and try out the Booner's with 10% barley and 10% rye. I'm also going to try two batches as a yeast experiment. 1 batch with red star bakers and one batch with us-05.
