Reflux condenser preventing vapour product
Hi All,
I cant seem to figure out what the problem is:
When running my still if the coil condenser has any water through put at all then nothing comes off the lieblig condenser. I am running a water vinegar mix at the moment to clean it after some soldering but cant imagine this should work differently to booze. If I shut off the flow to the condenser i get product but not otherwise. At the moment i'm running it unpacked - i cant see how packing would make a difference though. Have I buggered up my my design?
All the best
All the best
Re: Reflux condenser preventing vapour product
Is there some kind of lip or shelf on the inside of the pipe before the condenser? How is your liquid supposed to get into your output pipe?
Where did you get the design from for the built.. from the picture you have put together a VM design..
What type of valve is in the vapor outlet path.. plus you should be condensing vapors on a water run and should be able to see the condenser condensing the vapors..
Do you have a hole at the top of the condenser.. a hole is required so as to allow it to not be under pressure..
Mars
Mars
– Albert Einstein
– Albert Einstein
Hi thanks for the prompt response
Yes there is a hole at the top of the condenser
The coil condenser is tri clamped onto the top of the still
Yes running a VM still, basically this design viewtopic.php?f=17&t=41381.StillerBoy wrote: ↑Mon Jul 27, 2020 8:00 am Where did you get the design from for the built.. from the picture you have put together a VM design..
its a ball valve (i know not ideal but was free from a buddy) which is fully open as indicated. Yes on the previous water run and now this water/vingear run i can see the coil condenser at the top of the column working -StillerBoy wrote: ↑Mon Jul 27, 2020 8:00 am What type of valve is in the vapor outlet path.. plus you should be condensing vapors on a water run and should be able to see the condenser condensing the vapors..
How much power and what type of power are you using..
Mars
Mars
– Albert Einstein
– Albert Einstein
Also.. to improve the RC efficiency, ss scrubbies should be wrapped around the condenser coil so as to provide a tight fit, and some in between the coil and center.. that may help solve your issue..
Mars
Mars
– Albert Einstein
– Albert Einstein
Two low density 3000W electric heating elements - with controllers. Only had one running at 3000W when having this problem trying to get product to come off.StillerBoy wrote: ↑Mon Jul 27, 2020 8:17 am How much power and what type of power are you using..
Mars
Some product did come off when had both honking but when operating as a VM reflux I going to have only one running at like 1500 W so thought i should test like this.
The condenser is knocking down whatever i send at it fine - the problem is this seems to be effecting the vapor product stream. When i run the still as a pot still - placing a blank where the tri clamp is for the condenser - it runs fine.
Don't know where the idea that running it at 1500w will do the trick with a water run.. once you get into doing a scarifical run, then you will start to get some idea of what it is capable of doing and how much power to use.. the condenser in it's present form will be the weak link..Big L wrote: ↑Mon Jul 27, 2020 8:25 am Two low density 3000W electric heating elements - with controllers. Only had one running at 3000W when having this problem trying to get product to come off.
This is water, not low wine you are experimenting with.. you need to power upper with water to get the result you are looking for..
And what size is the ball valve inside..
Mars
– Albert Einstein
– Albert Einstein
Ah okay yes that makes lots of sense thanks.StillerBoy wrote: ↑Mon Jul 27, 2020 8:34 am Don't know where the idea that running it at 1500w will do the trick with a water run.. once you get into doing a scarifical run, then you will start to get some idea of what it is capable of doing and how much power to use.. the condenser in it's present form will be the weak link..
Mars
And also thanks for the condenser advise will pack with SS scrubbers for the sacrificial run!
The ball valve is 42mm internal i believe same as the pipe its place inline with. Is that a problem?
All the best
I don't think it will be an issue.. but often time, I've seen installed valve that were to small in relation to the pipe diameter..
On your sacrificial run is where you will see the different..
Also at that time, experiment for yourself with installing scrubbies in the condenser.. start without and see the efficency by the amount power used to overcome the condenser.. do this in slow/small increasement so as to reduce vapor surge.. then shutdown and add the scrubbies properly packed (need to be packed tightly and not loosely place) and see the different in the power requirement before the condenser is overcome.. again do this in slow/small increasement so as to reduce vapor surge..
Mars
– Albert Einstein
– Albert Einstein
check for a leak. the design is sound and if i understand correct you have 6kW... the leak may be your liebig... but a water run is different from alc.
My first flute
My press
My twins
My controller
My press
My twins
My controller
- MartinCash
My VM stil makes no product with vinegar, only with alcohol.
To do my cleaning runs I always have to stopper the top and run it like a pot still. This is probably because VMs take advantage of gaseous ethanol being heavier than water, but this is not the case with acetic acid (vinegar) or plain water.
4'' SS modular CCVM on gas-fired 50L keg.
A lot of stills behave very differently on a vinegar cleaning run than they will with wash in the boiler.
Also agree ,run a sacrificial Alcohol run and you will see how its meant to run .
Thanks all! Very helpful comments
