Reflux packing?
Reflux packing?
First off, thank you to everyone who has been so helpful in answering the novice questions im having, its brought me a long way and i just wanted to say thank you. Now for the question.
Ive read that a lot of people use tightly/highly packed columns to reach azeo or 190 proof, Is this also true with a reflux column? If so, where do you put the packing say in a 4 column section with bubble plates? This question stems from my other thread where Im looking at a 6 plate column but if I need to maybe take out a few bubble plates and put some saddles or prisms in, do I really need 6 column sections or can I do this with 4 and pack them for vodka runs? Im ready to buy the column parts but dont wanna waste on unnecessary things if I dont have to, still have to get a controller for the elements.
Re: Reflux packing?
https://homedistiller.org/forum/viewtop ... 17&t=66732
Have a read here, I think you may be combining two separate things or your terminology may be off
Re: Reflux packing?
a reflux column may either be packed or have plates in. the requirement is a reflux condenser... there are a few different types of reflux heads.
a plated column will make high proof flavour products, while a packed column is mostly used for neutral products... but that is the simple version.
My first flute
My press
My twins
My controller
My press
My twins
My controller
Re: Reflux packing?
IMO this is where the confusion starts , and what happens when people start not using the right terminology for stills and the parts of them.
What the hell is happening to hobby distilling when people don't know the difference?
A proper reflux still and a plated column on a hobby scale do very different things, one makes and is designed to make Vodka or Neutral type spirits, the other is for making flavoured spirits like Whisky , Rum , Brandy ect.
One runs a thing called a REFLUX condenser which condenses everything that hits it , the other runs a DEPHLEGMATOR ......learn the difference folks
...... what a DEPHLEGMATOR does ~~~~~> https://www.thermopedia.com/content/691/
Re: Reflux packing?
i very strongly disagree. a dephlegmator is a reflux condenser used on a Cooling Management reflux system. you can use CM on a plater or on a packed column. a plater does not have to be CM, either. if you do not believe me, check my signature. or search HD for LM and CCVM flutes/platers. and then explain to me why a reflux management system is different on a packed column than a flute/plater?Saltbush Bill wrote: ↑Tue Jul 27, 2021 1:59 amIMO this is where the confusion starts , and what happens when people start not using the right terminology for stills and the parts of them.
now, if you were to say my post was incomplete you would be correct. i should have added that platers, although reflux columns does not use packing but plates.
but you are correct that platers do a different product, as i have said.
edit: the difference in products between platers and packed columns has nothing to do with type of reflux management systems but rather the efficiency of the media or plate to facilitate reboiling phase change in the refluxed liquid.
My first flute
My press
My twins
My controller
My press
My twins
My controller
- S-Cackalacky
Re: Reflux packing?
No one mentioned adding a packed section to a plated column for neutral spirits. I think this may be what TRK41 was alluding to in his not so well worded OP.
Re: Reflux packing?
These arguments always arouse turned on debates and I understand it, when you have such a strong passion! I believe they are right a bit of all: the base would be a column packed by neutral and plates column for flavored spirits. As we know there are nuances for example you can very well make an aromatized on a column packed if you know how to manage it. Same thing for the reflux capacitor, traditionally a deflemmer is associated with the plates but I run a CCVM head on the plates column and, once again, it works if you know how to use it. In any case it is always better to use "the right tool" for the job you do but sometimes you can do more things with a single tool.
- Twisted Brick
Re: Reflux packing?
Nomenclature and terminology aside, you would do well to do some more background reading before proceeding. From the myriad of rookie questions you asked on your other thread, there is a sizeable list of distilling principles and concepts you need to grasp prior to pulling the trigger on a 6” plater to make NGS.
Just a suggestion, but your learning curve would be shortened by some serious reading and cutting your distilling teeth on a pot still. Too often we see new guys unwittingly invest in the wrong type/size/design still and after suffering frustration, either upgrade to the right tool for the job or walk away.
Re: Reflux packing?
im sorry guys, i didnt use the correct terminology, ill learn from it next time. I would guess "plated column" is what i meant to say. I was wondering where do you add them? Do I put it in the plated column reducer(8 to 4) at the bottom of the plated column? Or do you add them on top of a plated section? Or do you take out a plate and add them all between the 2 plateless sections? Thanks guys and sorry again, im still new to this.
Re: Reflux packing?
I get what you are saying but isnt this forum to ask and learn? Its why im here, to learn what im doing wrong and try and correct things before I dive into something I may not be prepared for. My questions are about topics that arent too talked about here like 6 inch columns and jacketed boilers. I've made it known im a novice and dont have any equipment and am in the honeymoon phase of trying a new hobby, apologies if im asking redundant questions, ill be sure to do more reading before asking more questions.Twisted Brick wrote: ↑Tue Jul 27, 2021 9:44 am .
Re: Reflux packing?
I sought of understand your initial question and think I know what you are asking TRK, what people think is that you are trying to pack a plated column. Just understand that the two things as SBB points out do different things. Maybe use the search function and type in modular, have a good day and good luck
Re: Reflux packing?
Thanks Sporacle, modular helped out a lot, getting this terminology down is like the ACT lolSporacle wrote: ↑Tue Jul 27, 2021 12:50 pm I sought of understand your initial question and think I know what you are asking TRK, what people think is that you are trying to pack a plated column. Just understand that the two things as SBB points out do different things. Maybe use the search function and type in modular, have a good day and good luck
Re: Reflux packing?
When you’ve been on these forums for a while, it is easy to lose patience with people wanting to learn everything at once by being “spoon fed”. Tip for anyone, not just TRK, you will get great and considered advice when you demonstrate through your questions that you are doing your own researching and showing some knowledge of the basics.
Twisted Brick gave great advice ie learn your craft on a pot still. I’d elaborate on that by recommending a 2” modular electric system involving a power controller. Learn to become boss of that still and the transition to a reflux column still will be very straightforward.
Modular 2" Pot Still
Re: Reflux packing?
That's great advice Kimbodious. I've got my 2 inch pot running pretty well now and run it by output, no thermometer just a scr. I'm in the process of building a CCVM and am really glad I waited as it works differently to how I first believed it to work. Managed to score a cheap 50L keg for a new boiler and have been to all the second hand stores and scrounged through my shed and am nearly finished a all copper 1L mini pot still
Re: Reflux packing?
Sure does! But if you are used to running a pot by the output, the CCVM will be a cinch!
- Deplorable
Re: Reflux packing?
+1kimbodious wrote: ↑Tue Jul 27, 2021 4:21 pmSure does! But if you are used to running a pot by the output, the CCVM will be a cinch!
