Botanicals - Powdered vs. Raw Form
When specifying quantities in Gin recipes some things are clear. Pepper corns are counted, dried citrus peel is weighed but then we get things that come in both root / bark form or these can be ground.
When one reads a recipe what is s convention; is the botanical measured in whole form or in powdered form, I am specifically referring here to;
Cassia Bark
Orris Root
Angelica Root
Further to this, when macerating botanicals surely a powdered form will impart character almost immediately. Reason for the question. I need to get some botanicals macerating, I am missing 2 which come in powdered form. Cn these be added a couple of days before doing the spirit run.
Cassia Bark
Orris Root
Angelica Root
Re: Botanicals - Powdered vs. Raw Form
Andrew,
I typically use the X/10 and X/100 formulation using weight as the measure. I have a triple beam scale and I can accurately weigh to 0.1 gram, so it works adequately when batching a gin recipe.
As to whether to use “powdered” or whole botanicals, I always prefer whole botanicals as they have a much fresher quality. Powdered spices lose a lot of the freshness due to processing and packaging. And specifically juniper berries are best when a little moist (squeezy). I usually crush the botanical in a mortar and pestle right before macerating. The smell is wonderful.
p.s. - Always keep a record of what you weigh or measure so you can “hone” the recipe to your preference on subsequent batches. Practice makes perfect.
SS is correct , weight is the way to measure......there can be no mistakes that way,.
Whole spices crushed as you need them will provide better flavour than those bought ready ground.
Cassia bark needs no grinding , just break off the size / weight piece you want and add it to the mix.
- NZChris
Cassia Bark
Orris Root
Angelica Root
I use all of those without grinding. The roots I slice or chop when harvesting.
Orris Root
Angelica Root
Many thanks gentlemen.
And what are people's thoughts on grinding/powdering prior to infusion/maceration? I would expect to get more extraction from the herbs that way.
- Rrmuf
Personally, I avoid grinding altogether. I mildly crush them in a pummel and have seen people use a blade coffee grinder but only lightly. .... and I am extremely careful with the Cassia (in the vapour path) because the only bad gin I've made taste like Cassia and nothing else. I want to try it again, but it will be with considerable care
-- Rrmuf
- Rrmuf
+1 .... I've read the same and got very similar guidance apecifically on juniper berries, but I cannot say I've really tested it.Saltbush Bill wrote: ↑Fri Nov 26, 2021 6:22 amThere is no need to grind so fine.
I have read that a too fine grind can add bitterness to a gin.
-- Rrmuf
- higgins
I use a blade grinder and grind rather finely. I've not perceived any bitterness in the OEGs that I've made, but I'll try using a mortar and pestle for the next batch as a comparison. It may be a few more weeks, but I'll report back.
Higgins
Flute build
Steamer build
4 methods experiment
Aging proof experiment
Next up:
Bourbon (71% Corn, 19% flaked rye, 10% malt, pot stilled)
Single Malt (74% pale malt, 22% vienna malt, 3% crystal 10, 1% chocolate)
Flute build
Steamer build
Next up:
- Rrmuf
One botanical I use in powdered form is licorice root.... a bit by default since it is the only form I could readily get it in.
Aside from that Oris root is particularly hard so I literally have to crush it with pliers to open it up. Not a real problem because I end up using only a little bit.
-- Rrmuf
