Bubble plate section size to maintain throughput on 2" packed column
andrew_987789
Hey all,
I currently have a 2" packed column and am playing with the idea of adding a bubble ball to it for experimentation as a tails trap.
By the nature of it's design a 2" bubble plate is going to have lower rate of vapor throughput compared to the column, I'm sure.
My question is, what size bubble plate is going to be appropriate to achieve the above, without restricting throughput to the above 2" column.
4" ?
3" seems potentially borderline / not enough?
Any larger than 4" I expect may be overkill?
Thanks in advance for sharing any experience.
4" ?
drmiller100
Re: Bubble plate section size to maintain throughput on 2" packed column
Bubble ball????
andrew_987789
Yep. In short, you have your boiler, a single bubble plate section, then your preferred still head/column on top.
The intended effect is that the bubble plate section works to trap/compress tails into a smaller section towards the end of the run.
Have a read here - viewtopic.php?t=31896
- Stonecutter
No sense starting small.
If you are able, start with 4” you could always compare results with a 3” later.
Good luck
Good luck
-Thomas Paine
-Thomas Paine
- bcook608
Looks like he was using a 4" Bubble plate sandwiched between 2 4x2 reducers with a sight glass.
Not sure I understand why you would want to trap tails at the bottom of the column . It makes more sense to let them fall back into the boiler unless for some bazaar reason you might want a trace of tails in your product .
- bcook608
for a one and done whiskey that sounds like it would be beneficial?
Maybe I'm wrong though. I'm still just a simple Pot head
I'm with Yummy, if you want less tails but them back in the boiler, a longer column, and or ,more reflux/ lower take off speed will achieve the same thing. A plated section below the packed wont work any better, and maybe not as well , as utilizing the same amount of space/ height with extra packed column.
andrew_987789
Experimentation. Fun. Knowledge. Why the hell not try it
andrew_987789
Fun to try in any case. Never let the nay-sayers talk you out of trying things
andrew_987789
I hear you, though I've done all that.Saltbush Bill wrote: ↑Sat Jul 30, 2022 10:32 pm A plated section below the packed wont work any better, and maybe not as well , as utilizing the same amount of space/ height with extra packed column.
Have run my column as is, and with extensions, to be 12:1 ratio in height, 21:1 in height, and 25:1 in height. Fully packed in each instance.
Now interested in the potential effects of running it through a liquid fill plate as opposed to a packed column.
andrew_987789
Go for it ......no one stopping you......you asked for opinions you got them.
Fact remains the same , it wont trap tails any better than more length and packing.
andrew_987789
Indeed I did. And while well-intentioned input is welcome, several of the comments have not actually touched on my question.Saltbush Bill wrote: ↑Sun Jul 31, 2022 1:22 am Go for it ......no one stopping you......you asked for opinions you got them.
Alternative theories to using a bubble ball do not equal experience in using one.
That may well turn out to be the case. Though there is reading about something on the internet, and there is completing the experience yourself; the former is far less valuable, I'm sure you'd agreeSaltbush Bill wrote: ↑Sun Jul 31, 2022 1:22 am Fact remains the same , it wont trap tails any better than more length and packing.
The question remains, what size bubble ball to play with while maintaining the same throughput
Imo ball or plate size will be less important than having a down commer / down commers that can easily handle the volume of returning reflux.
That will be the bottleneck in the system, Id go 3 inch minimum. Perforated plates or bubble caps that are even remotely flooded will always preform at way less than optimum and will let tails through. Id also suggest that at the speed that a normal 2 inch reflux column can process quality booze that a 4 inch plate is probably not necessary.....again downcomer performance is what will dictate the outcome.
Some may look at them as alternate theories....others may look at them as unsuccessful experiments conducted by many people in the past.andrew_987789 wrote: ↑Sun Jul 31, 2022 2:39 am Alternative theories to using a bubble ball do not equal experience in using one.
OK , that sounds fair . I have to say that the intense Butanol from the tails that I get when I drink Jack Daniels is certainly a characteristic taste and I can understand that as a reason to want to do that .
I was basing my comments assuming that most that use a packed reflux still are after a Neutral spirit devoid of any hint of tails .
I guess we don’t all run packed stills purely for Neutral .
GrumbleStill
Hi Andrew,
The question you have asked is what size plate to maintain throughput of your column. TBH, it seems like you may have left out some important information that would help answer your question. Most importantly, what throughput are you currently getting?
The reference design, the “Bitch”, didn’t have a column at all, just the 4” bubble ball and shotgun dephlag parked under the riser of a regular milk can pot still. It looked kinda awesome, and I guess probably allowed the operator to push his pot a bit harder without compromising quality.
Putting the plate under a packed column is a different animal, and knowing the performance of the column might help the experts point you in the right direction.
Cheers
Grumbles.
Cheers
Grumbles.
The question remains, what size bubble ball to play with while maintaining the same throughput![]()
I'd get a 6" ball with bubble cap plates.
Bubble caps can be turned down low if needed to match the 2" column.
If you're going to use the plate for a tails trap. It would be best if it was big and driven gently.
- LWTCS
The bubbleball concept is not really about a tails trap at all.
It's more to do with boosting the proof of what is feeding the column.
The debate about bubble balls was that they take up more height with only a single plate to show for it compared to the same height of packed column. Theoretically, the addition of one plate shouldn't really have a profound impact on a well spec'd packed column.
And yet minime was able to conclusively demonstrate that the bubbleball addition to the base of his column absolutely hacked his temp gradient by allowing his column temps (particularly at the base) to remain lower for a longer period of time. This isn't speculation. He logged and posted the data over at the Artisan site.
What is speculation is why does this happen when within the same height, packing will provide more theoretical plates?
My theory why this happens has always been about heat management.
It takes X amount of heat to flash alcohol in a kettle with say a 10% abv. After that first phase change cycle occurs what is the typical, approximate abv of the resulting condensed vapor? 35%? 50%? 70%?
It doesn't really matter. The point is that it is definitely higher than the original abv in the kettle. In fact the resulting vapor will always be higher abv than what remains in the kettle at every stage of the run.
And so now it will take that much less heat to flash alcohol at this next plate level. But what happens to the surplus heat needed to create vapor in the kettle? Well usually it will infiltrate the base of the column and exert itself upward.
The column packing typically retains less liquid mass for the same amount of height occupied by the liquid bed on a plate. And therefore the liquid bed on the plate has the ability (capacitance) to store more heat. Basically act as a heat sink or a break. And since it is the abv on the plate that will determine the flash point of the next phase change cycle, it is my assertion that the deeper liquid bed on the actual plate acts as a better heat sink and helps the column cope with what would otherwise be unneeded heat. Heat that would prevent the column from performing optimal separation.
So it's not really about the measly contribution that one single phase change cycle provides. It's more about more precisely managing the heat entering the base of the column and allowing more of the packing to more precisely separate inspite of it's otherwise limited turndown ratio.
- Ben
Incorrect. You will produce the same volume of vapor for a given heat input regardless of the diameter of the system, the vapor speed increases if the available cross section decreases. This is true as long as you aren't pressurizing the system. Liquid behavior coming back down is a different story.andrew_987789 wrote: ↑Sat Jul 30, 2022 7:17 pm
Oatmeal
So I bilt one in an 8" sphere. The plate is 6.37". This was modeled after the fu man build. The long and the short of it, is it was one of the better dumb impulses I've had.
Just ran it last night under a short packed 3" column to make rum.
The run before that I ran a 1 and done rum run + feints, quite barbarously in 3 hours and still turned out a decent finished product.
Prefer the pot for whiskey, as the hybrid column made a lighter flavor than I'd prefer.
In sum, build a big one. I'm likely to build another for a hybrid inline column thumper/retort...
- Stonecutter
I’ve always thought a thin layer of raschig rings at the top of the column was the best type of hybrid for a whiskey. You can always add more if you want it lighter. The trick is the type of screen used to retain them. I’ve not experimented with the marbles (smooth or rough) yet.
Double runs are hard to beat though
-Thomas Paine
-Thomas Paine
- Stonecutter
I’ve used the rings on my spirit run as well. Small bit to make a lighter spirit. Reminds me of when Finland under control of Russia classified Whiskey as a neutral.
-Thomas Paine
-Thomas Paine
- LWTCS
Just a nickname for an add on pair of joined half spheres with a bubble cap plate separating each hemisphere.
It was an early experiment that came on the heels of the Magic Flute popularity.
It was just a single plate section that had a cool aesthetic.
Later replaced by the Torpedo, also a single plate add on component.
Setsumi
My first flute
My press
My twins
My controller
My press
My twins
My controller
- bluefish_dist
I aLways ran one under my vodka column. I just happened to make my still opening 6” and would put a plate on the opening then attach the column which happened to be 4” or 6”. I would do a 4” at minimum for a 2” column. Never tried mixed packing and plate with a flavored spirit.
Formerly
Dsp-CO-20051
Dsp-CO-20051
- TwoSheds
FWIW, and I know it's not exactly the same, but I ran some neutral through 3 plates and 18" of raschig rings, all 3". I managed to pull 95% off the spout, which was part of the goal (I didn't have enough rings for a higher packed section) but the heads/hearts/tails separation wasn't as good as when I run through 36" of rings in my 2" section and the overall product was slightly less neutral, though still usable.
So, again for neutral, I'm back in the search for SPP, but if I can't find it before I need more neutral then I'll buy a few more liters of Raschig rings and do a longer column.
- LWTCS
Actually, this makes more sense than the plates providing a "Tails Trap". Plates are well known to trap and hold tails constituents.TwoSheds wrote: ↑Mon Aug 01, 2022 6:05 am FWIW, and I know it's not exactly the same, but I ran some neutral through 3 plates and 18" of raschig rings, all 3". I managed to pull 95% off the spout, which was part of the goal (I didn't have enough rings for a higher packed section) but the heads/hearts/tails separation wasn't as good as when I run through 36" of rings in my 2" section and the overall product was slightly less neutral, though still usable.
I have posted this analysis previously to illustrate.
Shoot sorry for the lousy scale of the attachment.
All three of the stills ran the same beer. And presumably the same or similar power input.
This any better
- TwoSheds
