Sporacles 4 inch plate build
Sporacle
So I've finally got my ducks in a row and am embarking on a 4 inch 4 perf plate build.
I will try and keep it sequential and post as much as I can.
Plates are flattened 2 inch with 1.5 mm holes on a 5mm grid, about 208 holes in total, square areas are TBA for downcomer and weir.
There is a central hole that the pattern is based on that allows me to spin the plates round.
Everything is centre punched and the plates are lubed with lanolin spray prior to drilling.
GrumbleStill
Re: Sporacles 4 inch plate build
Looking forward to following the build
Sporacle
Modules cut, 3 plate and a single plate.
Spacing is 120mm and a rough layout of the sightglass mounts
- Stonecutter
What an undertaking. Much respect for you guys who take the time and effort into researching and ultimately building your own sight glass columns. I
took the Yankee way out and bought a rig and itβs done me good so far. Iβve passively read a little about the math involved with the perf plates and spacing. However, itβs looking good from here man. I wish you the best of luck getting erβ up and running Sporacle.
-Thomas Paine
-Thomas Paine
Sporacle
Stoney, there is so much info out there. Luckily Old Dogs plans are still about and guys like Salty and Yummy are so helpful. Basically the plates and spacings are based on Saltys 4 inch still.Stonecutter wrote: βTue Dec 13, 2022 7:16 pm Much respect for you guys who take the time and effort into researching and ultimately building your own sight glass columns
It's coming along pretty easily atm, the next few days it will start to get a bit more complex.
Sporacle
Sight glass mounts are finished and the final layout is set, if you are building be very careful of your clearances around mounts and flanges.
I did a three stage set up
One was prior to cutting my modules, everything was taped and set out
Two was cutting and checking clearances
Three was a full assembly with plates measured prior to brazing and soldering
Wrapping the main column in sandpaper or wet n dry really is the easy way to getting a perfect fit for the sight glass mounts.
Btw ......dont drill the mount holes before soldering the mounts on....much easier to drill them out later and clean up with a small file or die grinder.
Sporacle
Thanks Bill, getting drilled after and ran them over the 4 inch with some 80 wet and dry sandwiched In-between, worked really well
Sporacle
Dephlegmator started, 4 inch height with 4 one inch tubes with half inch inlet and out let.
The whole unit will be brazed (or I think some country's call it hard soldering)
The plates are templated with grid paper and the ends are cut with a thin blade on a 100mm angle grinder, holes are centre punched on one plate.
I then put a reference line on the plates and the pipe so the plates return to the same spot on the pipe as I'm doing the fit.
When I'm happy with the fit I match up the reference lines clamp and pre drill the plates and then hold down on a piece of ply and drill the 1 inch holes
It's much easier to drill the holes with a metal holesaw bit as opposed to a standard bit or step drill
Sporacle
Bit more progress on the dephlegmator fitted and white out, prepped for brazing
Archee72
Nice safety bootsSporacle wrote: βWed Dec 14, 2022 11:06 pm Dephlegmator started, 4 inch height with 4 one inch tubes with half inch inlet and out let.
Which side are you on Boy? Which side are you on?
ThomasBrewer
What's the thought on having the vapor tubes proud of the end plates? Are you going to come back later and cut them down flush?
Sporacle
At this point there is no plan to cut them down, they are facing upwards in the so they won't interfere with the vapor.ThomasBrewer wrote: βSat Dec 17, 2022 7:52 pm What's the thought on having the vapor tubes proud of the end plates? Are you going to come back later and cut them down flush?
Having them slightly proud helps a little with assembly.
The downward face is finished flush as in the photo a couple of posts back
Sporacle
Brazed, patience is the key. The 4 inch sucks so much heat that I found it easier to set the MAPP torch on the opposite side to where I was working with the oxy.
Started with the tubes and then moved to the outer shell that way I got a fairly even heat.
When you think its hot enough, wait a bit longer
Uncle Jesse
- Site Admin
Patience paid off. Looks very good.Sporacle wrote: βSat Dec 17, 2022 11:00 pm Brazed, patience is the key. The 4 inch sucks so much heat that I found it easier to set the MAPP torch on the opposite side to where I was working with the oxy.
When you think its hot enough, wait a bit longer![]()
Best not to have pipes protruding upwards on defleg.
Can cause pooling.
On the bottom it doesn't matter.
Can cause pooling.
Sporacle
Yeah, I can turn it around as I haven't put the ferrules on yet. Or I can simply grind them down.Saltbush Bill wrote: βSat Dec 17, 2022 11:11 pm Best not to have pipes protruding upwards on defleg.
Can cause pooling.
If the vapour is passing through the defleg when I'm producing is there a chance of partial condensation due to the protusion and thus the protruding tubes would not allow any pooled liquid to return to the plates.... makes sense now I think about it
Thanks Bill
- Demy
Good job
Yeah just grind them flush, you don't want to give any distillate of any type an excuse to sit on top of the dephlegmator, better to be safe than sorry.
Setsumi
Well done with your build. Do you have a number on the % open area per plate?
My first flute
My press
My twins
My controller
My press
My twins
My controller
Sporacle
So 1.5mm holes on a 5mm grid, Setsumi the plate is changing as I am now going to cap my downcomers so there will be an additional 25 to 30 holes.
Freedom units mm
Area of plate 7853
1.5mm hole 1.78 x 216 (original) 384
384 by 7853 times 100
Is a touch under 5%
30 more holes pumps it to 5.5
I read a lot of info on percentages and started to really confused, to many choices and my brain doesn't like to many options
I used the plate perforation spacing of a still that I know works well
I see you are 2mm on 6mm grid giving about 5.6
ThomasBrewer
Great plan. The top plate of a dephlag will always be below condensation temperature, so anything pooled there will continously smear your run. An end mill mounted in a drill press will make quick work of cutting them flush. You can buy them cheap on eBay if you need.Sporacle wrote: βSat Dec 17, 2022 11:29 pmYeah, I can turn it around as I haven't put the ferrules on yet. Or I can simply grind them down.Saltbush Bill wrote: βSat Dec 17, 2022 11:11 pm Best not to have pipes protruding upwards on defleg.
Can cause pooling.
Thanks Bill
Sporacle
Never run one before so I'll ask the question, if the top plate of the dephlag is always below condensation temp how does the product get over to the product condensor?ThomasBrewer wrote: βSun Dec 18, 2022 4:41 pm The top plate of a dephlag will always be below condensation temperature, so anything pooled there will continously
Setsumi
Yes, stats on open area for perfs are difficult to find. Thats why I ask. You will be happy with 5.5%.Sporacle wrote: βSun Dec 18, 2022 12:10 pmSo 1.5mm holes on a 5mm grid, Setsumi the plate is changing as I am now going to cap my downcomers so there will be an additional 25 to 30 holes.
Freedom units mm
Area of plate 7853
Is a touch under 5%
I read a lot of info on percentages and started to really confused, to many choices and my brain doesn't like to many options![]()
I see you are 2mm on 6mm grid giving about 5.6![]()
My first flute
My press
My twins
My controller
My press
My twins
My controller
Sporacle
1.5mm on a 5mm grid is what Saltbush Bill used on his 4 inch build and he seemed happy with that so I figured it was good enough foe me
I used that spacing on my 6 inch because it worked well on my 4 inch.....I used it on my 4 incher because a lot of people had used that spacing on their stills on forums that I follow and none of them had any complaints.
I wouldn't have a clue what percentage it is.....just that ,that size hole on a grid that size works on any plate..... 3 ,4 or 6inch....I don't need to know more.
ThomasBrewer
It's a function of heat/mass transfer. If you send enough vapor up through the heat exchanger, you simply overwhelm the surface area and some vapor passes. My dephlag exit water temperature is usually about 55-70 C depending on what I'm running.Sporacle wrote: βSun Dec 18, 2022 4:44 pmNever run one before so I'll ask the question, if the top plate of the dephlag is always below condensation temp how does the product get over to the product condensor?ThomasBrewer wrote: βSun Dec 18, 2022 4:41 pm The top plate of a dephlag will always be below condensation temperature, so anything pooled there will continously
Sporacle
Makes sense, thanks
- DAD300
Don't be afraid of your plates being too porous.
You can correct an over porous plate by laying some washers on it.
My 5 plate column x 8" dia plates are approx 10% open. and I adjust that by laying SS washers on them. I can actually tune each plate to hold what I want. as in Plate 1 has six washers, 2 has five, 3 has four,...
It becomes self adjusting to some degree. And I can hear the washers rattle like valve plates.
DSP-AR-20005
DSP-AR-20005
Sporacle
The porosity of the plates was something that confused me, to be honest the whole concept is a bit confusing. I am lucky that so many people who have built and run plated columns have been so helpful.
I only just grasp the concept of how the still works, so much like a tried and true recipe, I just copied the basic layout of a still that works very well.
I am looking forward to learning how to run it and further down the track the next still build
