What do they use to clear coat liquor bottles?
- Steve Broady
I have a tequila bottle with a really interesting shape, sort of reminiscent of a wooden carving mallet(of course I can’t remember the brand, having already removed the labels). As I was scraping the labels off today, I thought for a minute that I’d scratched the glass, which surprised me. Upon closer examination, it appears that the glass has a clear coating on it, probably to give it the look of blue green glass. I tried paint thinner and lacquer thinner, neither of which touched the stuff at all.
The glass itself is clear, which I like. Obviously, I can scrape the coating off, but that’s going to be a lot of work given the shape of the bottle. The coating is clearly not soluble in acetone, and presumably not in alcohol. Before I start throwing every solvent I can think of at this stuff and seeing what happens, I figured I’d ask here. Does anyone know what kind of clear coat is commonly used in the industry, if there even is a standard? Obviously, you can’t tell me about my bottle specifically since you don’t know what it is, but I’m hoping someone might be able to say “Oh yeah, they pretty much all use Product XYZ when they coat bottles.” Failing that, I’ll just do some experimenting.
- Chauncey
Re: What do they use to clear coat liquor bottles?
It may be a baked on glaze type thing. Try sanding a spot lightly on bottom and scuff the coating and then try solvent see if it comes up then.
- Deplorable
Try oven cleaner. That will probably loosen it if it's not a baked on glaze. If that don't work, try Turco aircraft paint stripper but be cautious with it. That shit is cuastic and will cause serious chemical burns on bare skin. (The waste is also hazardous and should be properly disposed of)
- Chauncey
Let's see a pic of the bottle
Ya Killin me here
Ya Killin me here
- Steve Broady
rustoleum aircraft remover from autozone then rinse it off, use gloves.
- Chauncey
Looks like something baked on.
That's a sauza tres generaciones bottle
- Steve Broady
I had a feeling you’d know the bottle! And yeah, it definitely feels baked on, or otherwise tougher than just paint. If I can’t get it off, no big deal. But it would be interesting to try.
- Chauncey
That's gonna be pretty hard imo
Sandblasting or something perhaps. Not sure you can blast glass bottles.that would etch it tho
If you have acetone, lay the bottle on it's side fold up 3 squares of toilet paper for 3 layers
dribble acetone to the point of saturation, and leave for a couple hours and see if it softens.
This is always my next step after water doesn't work.
After that a heat gun but breakage is a risk.
- Chauncey
I had the same thought about the heat gun
It could be a uv cured paint. They are pretty durable but you can scratch them.
