Hole size recomendations...
Mr_Beer
Post by Mr_Beer »
Distillate packaged in 1 quart wide mouth canning jars with Teflon liner on cap and normal ring/top.
Most threads acknowledge that a small amount of air exchange is required for the ageing process.
What is the general notion of hole size -- 1/64th inch or larger or ??
The idea would be to put hole in the Teflon cap liner and the lid itself -- probably offset by 90 degrees.
Any notions would be appreciated.
subbrew
Re: Hole size recomendations...
Post by subbrew »
I just leave the lid a but loose. If you don't really crank it down there will be enough "leaks" to allow a bit of air exchange
Deplorable
Post by Deplorable »
subbrew wrote: Wed Jun 21, 2023 6:41 am I just leave the lid a but loose. If you don't really crank it down there will be enough "leaks" to allow a bit of air exchange
+1
I have several jars aging with PTFE disc's and the ring. I don't use the steel lid at all. Just leave the ring loose it will vent as temps rise and fall in the garage just fine.
bcook608
Post by bcook608 »
I have about 3 gallons of UJSSM ageing in a 5 gallon Corney with the O-ring removed to allow air exchange.
I second leaving the jar lid loose.
Mr_Beer
Post by Mr_Beer »
Thanks for those who responded. No holes and loose lids seem to be the answer.
I appreciate your time to help.
Evil_Dark
Post by Evil_Dark »
I made cardboard (non corrugated) rings to replace the mason jar steel cap. The cardboard is not sealing the jar at all, but prevent too much air excange.
It breathe enough because the jars are in a closet, and when I open the door of the closet I can smell the whisky vapors aroma a little.
Evil_Dark
rolling
Post by rolling »
I've used a PTFE sheet with 4 pin holes in it, then the normal ring successfully. I used PTFE sheets that are about 4" square, don't trim them, and screw the lid down over the top.
Newtothis
Post by Newtothis »
Came for the header/thread title, very disappointed!
Newtothis wrote: Sat Jul 08, 2023 10:48 pm Came for the header/thread title, very disappointed!
Not wanting to go too far OT , but it’s fair to say ,nobody likes a Big A-hole …… did that help :ebiggrin:
Now , Back on topic
Oldvine Zin
Post by Oldvine Zin »
Yummyrum wrote: Sun Jul 09, 2023 12:54 am
Now , Back on topic
HaHa wondering what hole he expected
Stay safe
OVZ
