Induction Hob question
If it plugs in, post it here.
Cristoir
Post by Cristoir »
Hello there,
I finally upgraded my still to 25L (half keg)
I have Tefal induction hob https://www.amazon.co.uk/Tefal-IH20184 ... 305&sr=8-8
But it’s only works when your pot aligns with circle lines on hob otherwise it gives me an error.
Anyone could recommend induction hob that can be used with half of a keg pretty please! Thanks
MooseMan
Re: Induction Hob question
Post by MooseMan »
The base of a half keg is not flat though is it?
Cristoir
Post by Cristoir »
MooseMan wrote: Sun Sep 29, 2024 3:35 am The base of a half keg is not flat though is it?
Yeah, should’ve looked at base before buying, so it’s only gas stove the only option I guess?
MooseMan
Post by MooseMan »
Your best option is to put an element into the side of the keg, that's what pretty much everyone ends up doing.
IAmPistolPete
Post by IAmPistolPete »
You could get a diffuser plate [available off Amazon or wherever]. The induction heater heats the diffuser and the diffuser heats the pot, assuming there is enough contact area to the pot. It's usually stainless steel & it works well with induction heat units. I have one that I used to use but tbh the induction cooktop would cycle too widely on/off even on wattage settings that I gave up on it after a few runs. Something with a more controllable static power input is def better, like gas or an internal "electric water heater" with power control as suggested above. I will say that a 1/4 barrel [25l] can be tough to add an element tho due to the tight radius. Some "manual shaping" may be necessary [bang bang bang]
If you ever find yourself being chased by a pack of wild taxidermists, do not play dead.
EricTheRed
Post by EricTheRed »
MooseMan wrote: Sun Sep 29, 2024 4:01 am Your best option is to put an element into the side of the keg, that's what pretty much everyone ends up doing.
Yebo
And the the cycling on and ofg
Life has gotten interesting!
Salt Must Flow
Post by Salt Must Flow »
Is your keg the normal style or the tall skinny version?
This is a normal style 7.5 gal keg I made into a boiler.
I had a 2" Tri-Clamp ferrule welded as low as I could through the side of this keg.
Turns out it takes about 2.75 gallons just to cover the element. I've read many times where people claim to have installed elements lower somehow, but I've never seen them show exactly how they they did.
So if you do install an element in the keg, just consider the volume you intend to fill it, how much will exit the still and don't forget how much is required to keep the element covered.
IAmPistolPete
Good call SMF - I was thinking of the log-style, that's all I see in my area. Don't need much volume to keep it covered. Haven't seen a squat-style in years.
