This season I've managed to raid my grandpa's plum, pear and apple trees (he is old and not up to the task anymore). I am starting a ferment on all of them and am at a decision on how best to approach this for the end product to have a distinct aroma and flavor of the fermented fruit.
I've read the facts of infusion thread and while the discussion is more on botanicals it made me have some questions, but I didn't want to sidetrack the discussion in there.
I know a good fermentation is the first step and there are definitely things to improve on (more gadgets for testing) but that requires time and experience so I doubt I can change much here in a short time. I macerate, chunk the fruit into a barrel, and seal off (plums I de-pit first).
Nov the first thing that probably affects my end flavor is definitely added sugar (I add cca 10kg per 100l barrel, in freedom units, its 20lb per 20 gal, I think). Sugar makes neutral alcohol and that dilutes the flavor.
Some info on planned distilling
Boilercharge: 45L fastrun diluted to 30%
Thumper1: 5l wash
Thumper2: 5l fast run
Both thumpers are 20L in size
As for my approach to distilling I've read about rum makers and double thumpers how to promote more esters while distilling (although me being a beginer I'm not sure if I'm gonna get the desired esters) I was thinking of charging the first thumper with some fermented wash and the second with some fast run of the fruit. I've done this with my elderflower spirit and it definitely promotes a stronger flavor.
I hate it when ppl add flavors that make the taste of fruits so pronounced that it feels weird drinking it and I know there are limitation to how much flavor you can pass through in distilling.
Reading the infusion stuff and what alchemist75 brought up I'm rethinking my initial plan. I think I should buy some of the fruit(cause I've used all of it
Another idea that I got from reading the thread is to partially fill those 2 thumpers with fruit and let them be empty.
Id like to try all 3 approaches but I doubt time will permit it. Im not sure any1 is trying the 2 thumper method so I wont ask about that, what I want to know is from experience what worked better for enhancing the flavor for you guys, spirit vapor through cut fresh fruit or letting the fruit soak in fast run?
Goal is a clear liquid with clearly distinct fruit notes.
Thanks for sharing your info/insights with me.
