The Waltons Baldwin "Recipe"
- PossumPie
OK, OK, I know TV isn't real life, but I got thinking...I was watching "The Waltons" and the Baldwin sisters were making "the recipe" in their back room. The still looked to be a 55-gallon Copper still, but they had no cold water condenser. They had a VERY long coil of copper tubing going from the still to their collection keg, and no sign of cooling other than air. I got thinking, theoretically, that a long enough cooling tube would condense the ethanol steam into liquid without a water cooler.I know- "It's TV" but the theory seems theoretically sound. I would REALLY prefer not/ to run hundreds of gallons of water through my condenser...What do you all think???
The more people I meet, the more I like my cats.
- NZChris
Re: The Waltons Baldwin "Recipe"
It will work, but the speed you can run at will be limited by length, diameter and thickness of the coil and the air temperature and speed.
Fans and fins are ugly and noisy but help.
For a 55 gallon pot, I'm guessing 500 to around 1000 feet of 1" or bigger tubing would work.
Search air cooled condenser.
- BlackStrap
Here is a screen shot of the still from the Walton's TV show.
It does not look like a 55 gallon still, this is just a terrible setup...
If you didn't blow yourself up first...The way those coils are in the picture it makes it a closed loop setup. Like others have said and "air" condenser is a thing, and some have had good success with them.
This is not one of those setups
Most questions can be answered here http://homedistiller.org/ and here http://homedistiller.org/forum/viewforum.php?f=46
The one who cuts the firewood gets twice the warmth
The coil in the picture would be an absolute disaster, it sure was made for TV only.
- NZChris
The pot is an autoclave, normally used for sterilizing under pressure. It would have to hold quite a bit of pressure between pukes.
- jonnys_spirit
Is that jonny and jonny boy walton cooking up a drop? Well gawdamn!
Cheers,
jonny
Cheers,
jonny
- NZChris
I actually would like to hook up a pressure cooker of wash to a sideways spiral just to watch what happens if you try to make the Walton's recipe, Granny Clampett's rheumatiz medicine, or the M*A*S*H* still.
"Hold my beer and watch this!"
Safer not watched from your usual chair by an indoors still. I have web cams and remote controlled power switches that I can use and would run the still without being present, contrary to forum rules.
Always had a theory that feds turn a blind eye to film makers showing stills so long as the still looks so wrong that if someone copied it , it wouldn’t work .
- NZChris
Some of the Moonshiners stills should work.
I gave an air cooled condenser PossumPie, along with many other guys on this forum.PossumPie wrote: ↑Wed Mar 19, 2025 2:52 pm OK, OK, I know TV isn't real life, but I got thinking...I was watching "The Waltons" and the Baldwin sisters were making "the recipe" in their back room. The still looked to be a 55-gallon Copper still, but they had no cold water condenser. They had a VERY long coil of copper tubing going from the still to their collection keg, and no sign of cooling other than air. I got thinking, theoretically, that a long enough cooling tube would condense the ethanol steam into liquid without a water cooler.I know- "It's TV" but the theory seems theoretically sound. I would REALLY prefer not/ to run hundreds of gallons of water through my condenser...What do you all think???
Aluminium heatsinks is what I've used on the outside of the copper vapour tube, to dissipate all the heat energy.
It's not something I'd use for stripping or with my large boilers, it's just on a little gin still, but it works really well with zero water.
- PossumPie
Interesting! I am new to this, and have only a 6gal distillation pot with a worm can smaller pot. you've seen the cheapo "Chinese" stills. It works surprisingly well for what I paid for it but came with a HORRIBLE design flaw. They had the condenser sitting on top of the evaporator! The hottest part of the still. I took it all apart and put an elbow joint with a longer piece of tubing so that the condenser could sit a few feet away from the still. It has a cold water in tube and hot water out tube and wastes a lot of tap water. I sometimes freeze 1 gallon milk jugs full of water, fill the sink with water and float the jugs in it. Then I pump the water in and out of the sink. This uses much less water, but I'd like to research a water-free condenser.MooseMan wrote: ↑Thu Mar 20, 2025 1:00 amI gave an air cooled condenser PossumPie, along with many other guys on this forum.PossumPie wrote: ↑Wed Mar 19, 2025 2:52 pm OK, OK, I know TV isn't real life, but I got thinking...I was watching "The Waltons" and the Baldwin sisters were making "the recipe" in their back room. The still looked to be a 55-gallon Copper still, but they had no cold water condenser. They had a VERY long coil of copper tubing going from the still to their collection keg, and no sign of cooling other than air. I got thinking, theoretically, that a long enough cooling tube would condense the ethanol steam into liquid without a water cooler.I know- "It's TV" but the theory seems theoretically sound. I would REALLY prefer not/ to run hundreds of gallons of water through my condenser...What do you all think???
- PossumPie
I know, I know...TV isn't real life. The stills shown on MASH, The Waltons, etc. were constructed to look like what the "sterotypical" still looks like in people's minds. BTW, a pressure canner or autoclave is no less safe than an actual still. The danger doesn't come in the material used, it comes b/c at some point a still could become a CLOSED system (blockage somewhere downstream of the evaporator and it becomes a bomb. If you took the regulator off of a pressure canner, tightened the lid down but kept your tube clear from obstruction, it would work fine.
As I said in my original post, I'm NOT trying to recreate one, just postulating on the possibility of a non-water cooled system. A bit of researching after I posted shows that there are in fact such a thing. I don't think it would be practical for me, I'm just a small-time hobbyist. I've tried recirculating the same water through an icebath sink and back into the worm can, I don't have the right size pump to keep it cool though.
With some more mods you could definitely make an air cooled condenser for that setup.PossumPie wrote: ↑Thu Mar 20, 2025 4:17 amInteresting! I am new to this, and have only a 6gal distillation pot with a worm can smaller pot. you've seen the cheapo "Chinese" stills. It works surprisingly well for what I paid for it but came with a HORRIBLE design flaw. They had the condenser sitting on top of the evaporator! The hottest part of the still. I took it all apart and put an elbow joint with a longer piece of tubing so that the condenser could sit a few feet away from the still. It has a cold water in tube and hot water out tube and wastes a lot of tap water. I sometimes freeze 1 gallon milk jugs full of water, fill the sink with water and float the jugs in it. Then I pump the water in and out of the sink. This uses much less water, but I'd like to research a water-free condenser.MooseMan wrote: ↑Thu Mar 20, 2025 1:00 amI gave an air cooled condenser PossumPie, along with many other guys on this forum.PossumPie wrote: ↑Wed Mar 19, 2025 2:52 pm OK, OK, I know TV isn't real life, but I got thinking...I was watching "The Waltons" and the Baldwin sisters were making "the recipe" in their back room. The still looked to be a 55-gallon Copper still, but they had no cold water condenser. They had a VERY long coil of copper tubing going from the still to their collection keg, and no sign of cooling other than air. I got thinking, theoretically, that a long enough cooling tube would condense the ethanol steam into liquid without a water cooler.I know- "It's TV" but the theory seems theoretically sound. I would REALLY prefer not/ to run hundreds of gallons of water through my condenser...What do you all think???
It's all about surface area and getting rid of as much heat as possible, as quickly as possible, from the condenser walls.
Since aluminium heat sinks from computer systems are carefully designed to do this very efficiently, I've just used that concept and adapted it to sucking heat from a copper pipe.
Works well with relatively low power input but it's not efficient enough for stripping at full power.
- PossumPie
Interesting, I built my last tower computer from scratch, I could probably find some aluminum heat sinks around somewhere...Even if it's part water cooled, and part air cooled, the heat sinks would certainly help. They are designed to reduce the heat from a graphics card or CPU from 100 degrees celsius to a safer temp.MooseMan wrote: ↑Thu Mar 20, 2025 6:13 am [
- PossumPie
I love it...what is that hot water baseboard pipes?
viewtopic.php?t=56652
Mason jars, he was nice enough to supply a shit load of links to other aircooled info.
viewtopic.php?t=54596&hilit=air+cooled+condenser
If you have some spare or can find some, give it a go.PossumPie wrote: ↑Thu Mar 20, 2025 7:32 amInteresting, I built my last tower computer from scratch, I could probably find some aluminum heat sinks around somewhere...Even if it's part water cooled, and part air cooled, the heat sinks would certainly help. They are designed to reduce the heat from a graphics card or CPU from 100 degrees celsius to a safer temp.MooseMan wrote: ↑Thu Mar 20, 2025 6:13 am [
I drilled out round ones from CPU coolers to fit straight over the copper, and used the smaller ones from Northbridge chips and GPU cards as shown above.
- PossumPie
I LOVE it! As I mentioned, those heat sinks handle boiling temps (212F) on GPUs and CPUs. One challenge the PC world has had is to cool faster and faster chips. Liquid-cooled systems, high-efficient aluminum heat sinks, etc. I'd love to get my hands on a box of them. I only have a few from old Towers/laptops but I may see if I can get my hands on some more. have you put a thermometer on the tubing at various places to see how quickly it cools down?
- Steve Broady
Temperature isn’t really the issue. Pretty much any piece of metal can handle the temperature. It’s more about how many watts it can move. Our boilers run in the kilowatt range, an order of magnitude more than even the biggest consumer microprocessors.
Exactly SteveSteve Broady wrote: ↑Fri Mar 21, 2025 2:07 pmTemperature isn’t really the issue. Pretty much any piece of metal can handle the temperature. It’s more about how many watts it can move. Our boilers run in the kilowatt range, an order of magnitude more than even the biggest consumer microprocessors.
Same reason those Peltier coolers can’t cope either.
Surface area and airflow, in other words fins and a fan.
There are better options than computer heat sinks.
I've seen baseboard heating element (like shady posted) with ratings of 500 watts/ft with 1 psi steam without a fan. A six foot long element can be purchased for less than $100,
There is also spiral fin stock that can be added to a pipe of your choosing for a relatively low cost ($20/meter) and would have similar performance.
There definitely are materials that are more efficient than repurposed Ali heat sinks, but they are a long way from free!zach wrote: ↑Fri Mar 21, 2025 2:52 pm There are better options than computer heat sinks.
I've also checked on every visit to the scrapyard and have never once seen a baseboard element in the UK sadly, or I'd be experimenting with them 100%.
I did check temps with a digital laser thermo, and posted it here.PossumPie wrote: ↑Fri Mar 21, 2025 12:32 pm I LOVE it! As I mentioned, those heat sinks handle boiling temps (212F) on GPUs and CPUs. One challenge the PC world has had is to cool faster and faster chips. Liquid-cooled systems, high-efficient aluminum heat sinks, etc. I'd love to get my hands on a box of them. I only have a few from old Towers/laptops but I may see if I can get my hands on some more. have you put a thermometer on the tubing at various places to see how quickly it cools down?
I don't think I did it very scientifically but can't remember. It's in my Stock Pot Gin Still thread near the end.
