little 5 gallon Wallmart stock pot, but now it's time for something a little bigger. I love
all the beautiful copper creations some of you guys have built here but most of that is beyond
my skill level. My goal for the new still, apart form bigger capacity, was to build something
that was much better quality but keep everything as simple as possible, given my aforementioned
lack of skills. I decided to stay with a simple stock pot based design. I went down to my local
homebrew shop and found this giant 15 gallon stainless stock pot with a built-in heat spreader
in the bottom:
That sucker is over 18 inches in diameter and it is HEFTY. It wasn't cheap, but it will
certainly accomplish my goal of more capacity and I figured it would make for a simple build.
The pot came with a very nice sturdy lid so I figured I would just use that for the cap instead
of building a new cap. The only thing I needed to do was drill a hole for the take off pipe,
which is just a piece of 1 inch copper tube. I broke out my trusty stepped drill bit and drilled
the hole:
Next I needed to figure out how to attach the output pipe to the lid and clamp the lid to
the boiler. I wanted the take-off pipe connection to be as simple as possible. No fittings
or soldering/welding something to the stainless steel. I chose to combine the pipe attachment
and lid clamping function into one assembly by putting a small "shelf" on the bottom of the
output pipe that would allow me to place a "strap" across the shelf and press the output pipe
down onto the lid and at the same time apply enough pressure to the lid to keep it securely
clamped in place. Here is what the little shelf looks like:
The shelf was made using a 1 inch copper coupler and a two flat pieces of copper that I
made by flattening out a piece of scrap copper pipe with a hammer. The top shelf is for
the clamp to hold everything in place, and the bottom one is to press against the gasket
to seal the connection between the pipe and the lid. I slipped all three pieces onto the
bottom of the 1 inch output pipe and soldered everything together. Here is how the this
assembly sets in the hole on the lid:
I will use a simple gasket I made from some thin cardboard to seal the pipe connection to
the lid. I used this method on my old still and it worked pretty well.
Oh.... I guess I can only attach 6 pictures, but I'm not done yet
Give me a few minutes and I'll submit another post
