PSR-25 verses SSR-25
- drinkingdog
I am putting my heat controller together and I was thinking that I bought a PSR-25 but instead I bought this http://www.amazon.com/gp/aw/d/B008MPK4I ... w_d_dsc_hi" onclick="window.open(this.href);return false;" rel="nofollow Reading through the different controller threads and I see some of the SSR-25 need a 24 volt transformer. Do I need a transformer for the one I bought? I also bought a 2 w pot and a amp meter is there anything else I need to run my heating element?
My Grandpa used to say. Don't argue with an idiot, because he will just drag you down to his level then beat you with experience.
He also used to say. I didn't say it was your fault. I just said that I was blaming you.
DD
DD
Re: PSR-25 verses SSR-25
PSR's are resistance controlled and SSR's are voltage controlled... Well, that's just a simple comparison - and perhaps too simple... Voltage controlled require an additional control module whereas a resistance controlled only requires a right sized potentiometer, making them cheaper and simpler to set up...
- drinkingdog
So then I need to buy an additional control module and a transformer to make it work or just buy a PSR-25
DD
DD
No you don't need a transformer for that PSR. You need 10 Guge wires and a box.drinkingdog wrote: Do I need a transformer for the one I bought? I also bought a 2 w pot and a amp meter is there anything else I need to run my heating element?
- drinkingdog
So what I have then is considered a PSR?
DD
DD
Different brands have different names. You just need to know how that SSR or PSR is controlled.
Relay is OK If you see something like this:
Product Name : Solid State Relay Voltage Resistance Regulator + Heat Sink;Model : SSR-40VA
Rated Current : 40A;Resistance : 470-560k ohm
Buying a PSR and potentiometer is probably cheaper and better in the long run than sinking more money, time, and effort, into the SSR... Unless you can find a dirt cheap control module and power supply...
- drinkingdog
I know I'm not the sharpest tool in the shed so that probably is part of the reason why I'm confused. I think Sambedded you are telling me that what I have does the same thing that a psr-25 control module will do without adding any additional items except a pot amp meter and of course the proper wiring and housing to put it all in. Now I am also getting the impression from rad that I need other things like another control module and regulator to make what I have work. I don't have a bit of a problem buying a psr-25 control module to make things work if needed. I'm just trying to get my new baby up and walking around this weekend if possible. So if anybody can confirm what I have will work wired the same way as the psr-25 it would be greatly appreciated.
DD
DD
Just make a quick test setup using your SSR , any type of wire and connect a light bulb instead of heater. You will see immediately if works or not.
Reading your OP and researching the maker of the SSr it is indeed a Amico Solid State Relay Voltage Resistance Regulator. So all you need is a Potentiometer with a Resistance within 470-560K Ohm and your away.
- drinkingdog
Thanks Sambedded and Muddydisco. I appreciate the info. I did try hooking it up to a light last night and it worked like a charm. I can't wait to get all of this put together so as to finally get to try this 6 month project out. Starting to get excited about drinking something that I made. First stuff shouldn't be too bad since I'm sticking to the tried and true recipes for a while.
DD
DD
