Copper electrical wire
Haus
Location: When you get to the fork in the road, take it
Post by Haus »
Safe - Not safe?
I'm talking about the uncoated ground wire.
My assumption is that electrical wire is made from high purity copper in the first place, the answer is yes safe but is it treated with anything I am not finding in searches that cleaning would not even fix?
you can lead a horse to water but it's hard as hell to drown it
pfshine
Re: Copper electrical wire
Post by pfshine »
Its fine go ahead and use it.
+1 pfshine
I'd also recommend soaking the wire in vinegar before use.
Just out of curiosity, what is the wire for ?
Haus
Post by Haus »
I just remembered having to find a hook to get a scrubber out and got to thinking, dangerous I know, but if I could just attach the scrubber(s) to a wire and push them in, they just as easily could be removed.
carbohydratesn
Post by carbohydratesn »
Yeah, I've read at least one post from someone else about doing this successfully - it's a solid idea, go for it!
Bigbob
Post by Bigbob »
I just did the same thing, but instead of scrubbies I made a few coils in the wire and twisted the end down. Haven't tried them yet but I'll let ya know.
Bigbob
Post by Bigbob »
Here is what I did,made a few to check them out. Did not like the idea of sticking scrubbies up and trying to get them out. I haven't tried this out yet, but will let everyone know how they work!
Haus
Post by Haus »
I'm playing the idea of having 4 sections of copper mesh spaced apart. Kind of like how plates are configured, only removable for cleaning or changing. The wire would just run up the center of each to hold them in place. Not sure what effect if any it would make on final product but we'll see.
T-Pee
Post by T-Pee »
Go to the store and get one of these:
Wine screw.jpg (8.51 KiB) Viewed 8411 times
Remove the screw part and reinstall into the end of a 3' piece of 3/4" dowel with a little glue and Voila!
A handy dandy scrubbie remover.
What's nice is when you twist it in, the scrubbie narrows out and becomes very easy to remove. :thumbup:
tp (who did it the hard way...once)
pfshine
Post by pfshine »
I just grabbed one end and swung as hard as I could and let centripetal force do the rest.
Hound Dog
Post by Hound Dog »
Haus6565 wrote:I'm playing the idea of having 4 sections of copper mesh spaced apart. Kind of like how plates are configured, only removable for cleaning or changing. The wire would just run up the center of each to hold them in place. Not sure what effect if any it would make on final product but we'll see.
I don't see the real point in wasting space between the mesh but experiment with it and let us know. I may be wrong on that. I am sure though that if your mesh is loose enough that it needs something besides friction to hold it in place, it is way too loose. When trying different configurations try packing it way tighter than you think you should. I think you will find this yields your best results.
When I used mesh for packing I preferred it over scrubbies because you could roll tight sections consistently.
To the original post, Bushman has a method of making copper packing using cooper welding cable, which is fine stranded electrical wire. I haven't used this method but it seems like it would make a good dense copper packing.
Using Google Search
Bigbob
Post by Bigbob »
So I'm running some sweet feed today. Using the copper wire raccoon pecker bone. Works great! :thumbup:
This one you can see the coils
Cashjon
Post by Cashjon »
Is that can with the worm in it made outta copper? If so where did you ever find something like that? Or is it just the light? I like the raccoons pecker, good idea.
Bigbob
Post by Bigbob »
Yes the flake stand is all copper. The entire unit is from whiskystills.
cna8065
Post by cna8065 »
Man just use HCL of spirits of salt and it will clean up so fast you don't know what happened but rinse thoroughly
cna8065 wrote:Man just use HCL of spirits of salt and it will clean up so fast you don't know what happened but rinse thoroughly
Most here aren't well versed at working with such caustic solvents so your advice, while perhaps worthy for you, may not be the best for the general public... That's assuming that you are referring to Hydrochloric/Muriatic acid... We understand that you are new, and apparently eager to help, but we strive to keep members safe... Don't be trying to solve every members problems in your first 24 hours here... You should be doing research so you know how we roll...
cna8065
Post by cna8065 »
Fair enough man ill hush up for a while
I missed this thread when it first came out last year but I believe I was the first to post how to use electrical wire for mesh. It was not my original idea it came from Mash Rookie but I did make a tutorial on it.
http://homedistiller.org/forum/viewtopi ... 17&t=47650
Since making the tutorial I did add more packing thus I believe my original size should be increased.
